flash commands
carl_townshend
Hi all
Im want to create a crib sheet for flash commands for IOS handling, has anyone got a list of the main commands used and what they do, for example
1.creating directorys , moving files , viewing whats in a directory, deleting a directory and files inside it, formatting flash, installing an archive flash file, renaming etc etc
help much appreciated
cheers
Carl
Leo Laohoo
dir flash:
delete /force /recursive flash:
formatting flash
format flash:
archive download-sw ...
renaming
rename flash:original.filename flash:new.filename
Not supported.
Mike Williams
Level 6
Level 6
Create directory:
mkdir flash:/
As Leo pointed out, I do not believe you can move files.
Sent from Cisco Technical Support Android App
Hi.
To move files between directory you need first to copy them to the desired directory and them from the original position.
dir flash:
Directory of flash:/
    1  -rw-    66562172  Mar 29 2012 13:27:48 +02:00  c2800nm-adventerprisek9-mz.151-3.T3.bin
    2  -rw-     4832344  Mar 29 2012 14:20:54 +02:00  anyconnect-macosx-i386-2.4.1012-k9.pkg
    3  -rw-     3203909  Mar 29 2012 14:21:36 +02:00  anyconnect-win-2.4.1012-k9.pkg
    4  -rw-     5209423  Mar 29 2012 14:22:42 +02:00  anyconnect-linux-2.4.1012-k9.pkg
Router#mkdir newdir
Create directory filename [newdir]?
Created dir flash:newdir
Router#copy flash:anyconnect-macosx-i386-2.4.1012-k9.pkg flash:newdir/
Destination filename [/newdir/anyconnect-macosx-i386-2.4.1012-k9.pkg]?
Copy in progress...CCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCC
4832344 bytes copied in 16.860 secs (286616 bytes/sec)
Router#dir newdir
Directory of flash:/newdir/
  100  -rw-     4832344  Sep 19 2013 11:34:12 +02:00  anyconnect-macosx-i386-2.4.1012-k9.pkg
Router#delete /force flash:anyconnect-macosx-i386-2.4.1012-k9.pkg
You can also change directory by issuing cd dirname and check in which directory are you looking in:
Router#cd newdir
Router#pwd
flash:/newdir/
Carlo
Please rate all helpful posts
"The more you help the more you learn"
Please rate all helpful posts "The more you help the more you learn"
