Flash compatibility
I have a Flash of juniper router and I want to use it in cisco SUP 720. Is it compatable / please suggest if any procedure to make it compatable.
Leo Laohoo
Stick it into the Sup720 slots and format it using the command "format disk0:".
It may work. But not tested.
But as a best practice please always use Cisco Compatible memory devices, because if something happens wrong, then it may impact production.
Please test in a device which is not in production
Cheers
Somu
Rate helpful posts.
