WS-C3750E-48PD-SF
skrowocsic
Hello!!!
I have four WS-C3750E-48PD-SF stacked but I need to stack one more.
What are the steps I have to do to add a switch with the actual configuration?
I have to stop the other switchs or can I do the change without service loosing?
I have to pre-configure the switch or can I add with the factory settings?
Thanks for your help!!!
smogra
First decide whether you want to add the new switch as master of the stack or as just a member switch. Depending on that, go through this link to follow the steps:
Tips to ad d as masterhttp://www.cisco.com/en/US/products/hw/switches/ps5023/products_configuration_example09186a00807811ad.shtml#stack4
Tips to add as slave
The few basic configs will syunh up from the master switch.
Cheers
Sweta
Please rate the answers if it was helpul.
http://www.cisco.com/en/US/products/hw/switches/ps5023/products_configuration_example09186a00807811ad.shtml#stack3
Document ID: 71925
Introduction
This document provides the procedures to create and maintain the  Cisco Catalyst 3750 Switch Stacks with the Cisco StackWise feature.
Prerequisites
Requirements
There are no specific requirements for this document.
Components Used
The information in this document is based on the Cisco Catalyst 3750 Series Switches.
The information in this document was created from the devices in a  specific lab environment. All of the devices used in this document  started with a cleared (default) configuration. If your network is live,  make sure that you understand the potential impact of any command.
Conventions
Refer to the Cisco Technical Tips Conventions for more information on document conventions.
Background Information
Stacking Technologies
Cisco Catalyst switches can be stacked with two different features.
  • Cisco StackWise Feature
    Supported Devices/Modules:
    • Cisco Catalyst 3750 Series Switches
    • Cisco EtherSwitch Service Modules
    A switch stack is a set of Cisco EtherSwitch service modules or  Catalyst 3750 switches connected through their Cisco StackWise ports.  One of the Cisco EtherSwitch service modules or Catalyst 3750 switches  controls the operation of the stack and is called the stack master. The  master LED in the front panel of the 3750 switch turns green when the  switch becomes master in the stack. The stack master and the other Cisco  EtherSwitch service modules or Catalyst 3750 switches in the stack are  stack members. The stack members use the Cisco StackWise technology to  behave and work together as a unified system. Layers 2 and 3 protocols  present the entire switch stack as a single entity to the network.
    The stack master is the single point of stack-wide management. From the stack master, configure these:
    • System-level (global) features that apply to all stack members
    • Interface-level features for each stack member
    A switch stack is identified in the network by its bridge ID and, if  the switch stack operates as a Layer 3 device, its router MAC address.  The MAC address of the stack master determines the bridge ID and router  MAC address. Every stack member is uniquely identified by its own stack  member number.
    All stack members are eligible stack masters. If the stack master  becomes unavailable, the stack members that remain participate in the  election of a new stack master from among themselves. A set of factors  determines which Cisco EtherSwitch service module or Catalyst 3750  switch is elected as the stack master.
    Note: A Cisco 3750 switch can be stacked with any other model of Cisco 3750 switches. Catalyst 3750 switches that run Cisco IOS® Release 12.2(25)SEB are compatible with Cisco EtherSwitch service  modules that run Cisco IOS Release 12.2(25)EZ. Catalyst 3750 switches  and Cisco EtherSwitch service modules can be in the same switch stack.  Within this switch stack, the Catalyst 3750 switch or the Cisco  EtherSwitch service module can be the stack master.
  • Cisco GigaStack Feature
    1. Cisco Catalyst 2900 XL switches
      WS-X2931-XL module for Catalyst 2900 XL switches
    2. Cisco Catalyst 2950 switches
    3. Cisco Catalyst 3500 XL switches
    4. Cisco Catalyst 3550 switches
    The GigaStack GBIC adds port density and high-performance  connectivity to supportive switches. When installed in a supportive  switch, the GigaStack GBIC supports Gigabit connections in a cascaded  stack or point-to-point configuration. The GigaStack GBIC automatically  negotiates the duplex setting of each port to maximize the bandwidth for  your configuration.
    Refer to Cisco GigabitStack GBIC to install and troubleshoot Cisco GigabitStacks.
Stackwise Ports, Cables, and Connection Types
Ports
This is the rear-panel view of the Cisco Catalyst 3750-24TS, 3750G-24T, 3750G-12S, 3750G-16TD, and 3750-48TS:
No. Description
1StackWise Ports
2RJ-45 Console Port
3Fan Exhaust
4AC Power Connector
5RPS Connector
Note: The location of Fan exhaust, AC power connector, RPS  connector, and the number of Fan exhausts varies with the different  models of Cisco Catalyst 3750 switches.
Cables
Use only approved cables, and connect only to similar Cisco  equipment. Equipment can be damaged if connected to other unapproved  Cisco cables or equipment.
/image/gif/paws/71925/cat3750-12.gif
Cable Part Number Description
CAB-STACK-50CMCisco StackWise 50-cm stacking cable
CAB-STACK-1MCisco StackWise 1-m stacking cable
CAB-STACK-3MCisco StackWise 3-m stacking cable
Connection Types
Full Bandwidth Connection
This illustration shows an example of a stack of Catalyst 3750  switches that provides full bandwidth and redundant StackWise cable  connections:
/image/gif/paws/71925/cat3750-2.gif
When a cable fails at a single place, the stack will run with the half bandwidth connection.
/image/gif/paws/71925/cat3750-3.gif
In order to find the stack-ports through which the switches are connected to the stack, issue the show switch stack-ports command.
3750-Stk#show switch stack-ports
  Switch #    Port 1       Port 2
     1          Ok           Ok
     2          Ok           Ok
     3          Ok           Ok
Alternatively, in order to find the nearby switch on each port, issue the show switch neighbors command.
3750-Stk# show switch neighbors
      1         2            3
      2         1            3
      3         2            1
This illustration shows a stack of Cisco EtherSwitch service modules  and Catalyst 3750 switches that provides full bandwidth and redundant  connections:
/image/gif/paws/71925/cat3750-11.gif
Half Bandwidth Connection
This illustration shows an example of a stack of Catalyst 3750  switches with incomplete StackWise cable connections. This stack  provides only half bandwidth and does not have redundant connections:
When a cable fails at a single place, the stack will be partitioned into two stacks.
/image/gif/paws/71925/cat3750-4.gif
3750-Stk# show switch stack-ports
     1          Ok          Down
     2          Ok           Ok
     3          Ok          Down
     1          2           None
     2          1            3
     3          2           None
Creation and Management of Cisco Catalyst 3750 Stacks
In this section, you are presented with the information needed to configure the StackWise stacks described in this document.
Note: Use the Command Lookup Tool (registered customers only) to obtain more information on the commands used in this section.
Stack Member Numbers
The stack member number (1 to 9) identifies each member in the switch  stack. The member number also determines the interface-level  configuration that a stack member uses. You can display the stack member  number if you use the show switch user EXEC mode command.
3750-Stk>show switch
                                               Current
Switch#  Role      Mac Address     Priority     State
 1       Slave     0016.4748.dc80     5         Ready
*2       Master    0016.9d59.db00     1         Ready
The default stack member number of a 3750 switch is 1. When it joins a  switch stack, its default stack member number changes to the lowest  available member number in the stack. Stack members in the same switch  stack cannot have the same stack member number. Every stack member,  which includes a standalone switch, retains its member number until you  manually change the number or unless the number is already used by  another member in the stack.
How do you manually change the member number?
  1. Go to global configuration mode.
  2. Issue the command switch current-stack-member-number renumber new-stack-member-number .
  3. Return to the privileged EXEC mode and reload the member with the command reload slot current-stack-member-number .
  4. After the member boots up, issue the command show switch to  verify the stack member number. If the number is used by another member  in the stack, the switch selects the lowest available number in the  stack.
If you move a stack member to a different switch stack, the stack  member retains its number only if the number is not used by another  member in the stack. If it is used by another member in the stack, the  switch selects the lowest available number in the stack. The switch is  able to retain the stack member number as an environment variable. You  can also renumber a switch from the bootloader switch: prompt with the command set SWITCH_NUMBER stack-member-number .
If you merge switch stacks, the switches that join the switch stack  of a new stack master select the the lowest available numbers in the  stack.
Priority Values
A higher priority value for a stack member increases its likelihood  to be elected stack master and to retain its stack member number. The  priority value can be 1 to 15. The default priority value is 1. You can  display the stack member priority value with the show switch user EXEC mode command.
                                               Current
 1       Slave     0016.4748.dc80     1         Ready
*2       Master    0016.9d59.db00     5         Ready
Cisco recommends that you assign the highest priority value to the  switch that you prefer to be the stack master. This ensures that the  switch is re-elected as stack master if a re-election occurs.
How do you change the priority value?
  • From the global configuration mode, issue the command switch stack-member-number priority new-priority-value .
  • From the bootloader switch: prompt, issue the command set SWITCH_PRIORITY new-priority-value .
Even though the priority value applies immediately to the member, it  will not affect the status of the current stack master. New priority  value will play a role in the next stack-master election.
Stack Master Election
How is the stack master elected?
These rules have been defined to determine which unit within a stack  is chosen as the master. When switches are added or stacks are merged,  the master will be chosen based on these rules, in the order specified:
  1. The switch that is currently the stack master
    Note: When stacks merge, the elected stack master would have been the master of one of the merged stacks.
    Note: When stacks partition, the stack master of the original stack will be the master of its partition.
  2. The switch with the highest stack member priority value
    Note: Cisco recommends that you assign the highest priority  value to the switch that you prefer to be the stack master. This ensures  that the switch is re-elected as stack master if a re-election occurs.
  3. The switch that uses the non-default interface-level configuration
  4. The switch with the higher Hardware/Software priority. These switch  software versions are listed from highest to lowest priority:
    1. Cryptographic IP services image software
    2. Noncryptographic IP services image software
    3. Cryptographic IP base image software
    4. Noncryptographic IP base image software
    Note: Switches that run Cryptographic or IP services image  will take a longer time to load than Non-Cryptographic or IP base image.  When you power on or reset an entire switch stack, some stack members  will not participate in the stack master election. This is because stack  members that are powered on within the same 20-second time frame  participate in the stack master election and have a chance to become the  stack master. Stack members that are powered on after the 20-second  time frame do not participate in this initial election and only become  stack members. At times, switches with lower software priority can  become the stack master, but all stack members will participate in the  stack master re-election.
  5. The switch with the longest system up-time
  6. The switch with the lowest MAC address
Note: Data forwarding will not be affected within the stack master election.
When is the stack master elected?
  • When the whole switch stack is reset1
  • When the stack master is reset or powered off
    Note: If you reset the stack master, it would reset the whole stack.
  • When the stack master is removed from the stack
  • When the stack master switch has failed
  • The switch stack membership is increased by if you add powered-on standalone switches or switch stacks.1
1Within these events, the current stack master has a greater chance to get re-elected.
Hardware Compatibility
The Cisco Catalyst 3750 series switches use Switch Database  Management (SDM) templates to optimize the system resources for specific  features dependent on how the switch is used in the network. There are  two versions of the SDM templates: Desktop and Aggregator. The 3750-12S  switch alone supports both templates. All other model switches of the  3750 series support only the Desktop version.
When a Cisco Catalyst 3750 switch stack consists of 3750-12S and  other models, make sure to use only the Desktop SDM template. This is an  output from the show switch command when an SDM mismatch exists:
                                               Current
*2       Master    000a.fdfd.0100     5         Ready
4       Member     0003.fd63.9c00     5         SDM Mismatch
To change the SDM template on a 3750-12S to Desktop version, complete these steps:
3750-Stk# conf t
3750-Stk(config)# sdm prefer routing desktop
3750-Stk(config)# exit
3750-Stk# reload
For more information on the SDM templates, refer to Configuring SDM Templates.
Software Compatibility
Software compatibility between the stack members is determined by the  Stack Protocol Version number. To view the stack protocol version of  your switch stack, you can issue the show platform stack-manager all command.
3750-Stk# show platform stack-manager all
                                               Current
!--- part of output elided
                 Stack State Machine View
Switch   Master/   Mac Address          Version    Uptime   Current
Number   Slave                          (maj.min)            State
1        Slave     0016.4748.dc80          1.11        8724    Ready
2        Master    0016.9d59.db00          1.11        8803    Ready
!--- rest of output elided
Switches with the same Cisco IOS software version have the same stack  protocol version. Such switches are fully compatible, and all features  function properly across the switch stack. Switches with the same Cisco  IOS software version as the stack master immediately join the switch  stack.
If an incompatibility exists, the fully functional stack members  generate a system message that describes the cause of the  incompatibility on the specific stack members. The stack master sends  the message to all stack members.
Switches with different Cisco IOS software versions likely have  different stack protocol versions. Switches with different major version  numbers are incompatible and cannot exist in the same switch stack.
                                               Current
 1       Member    0015.c6f5.6000     1         Version Mismatch
*2       Master    0015.63f6.b700     15        Ready
 3       Member    0015.c6c1.3000     5         Ready
Switches with the same major version number but with a different  minor version number as the stack master are considered partially  compatible. When connected to a switch stack, a partially compatible  switch enters version-mismatch (VM) mode and cannot join the stack as a  fully functional member. The software detects the mismatched software  and tries to upgrade (or downgrade) the switch in VM mode with the  switch stack image or with a tar file image from the switch stack flash  memory. The software uses the automatic upgrade (auto-upgrade) and the  automatic advise (auto-advise) features.
The auto-upgrade occurs if the software release that runs on the  stack master is compatible with the switch in VM mode and the tar file  of the current image is available with any of the stack members. If tar  file of the current image is not available, the auto-advise feature will  recommend that a compatible image be downloaded with the required  commands. The auto-upgrade and auto-advise features do not work if the  switch master and switch in VM mode run different feature sets/packaging  levels (IP services and IP base), but, from Cisco IOS Software Release  12.2(35)SE, auto-upgrade does support upgrades between cryptographic and  non-cryptographic images of the same packaging level.
Note: If the auto upgrade does not work on the switch that shows the version mismatch error, use TFTP to manually upgrade the switch.
Create a Switch Stack from Two Stand-alone Stacks
This example shows how a switch stack is created from two stand-alone stacks.
  1. Switch-A and Switch-B are merged together to form the stack.
    /image/gif/paws/71925/cat3750-5.gif
    and
    /image/gif/paws/71925/cat3750-9.gif
  2. A stack-master election occurs between Switch-A and Switch-B; let us consider that Switch-B wins.
  3. Switch-A will reload itself and join the switch stack.
  4. The stack member number of Switch-A will change since it conflicts  with Switch-B. Switch-A will choose the lowest available stack number,  which in this case, is number "2".
    /image/gif/paws/71925/cat3750-10.gif
Create a Switch Stack from Two Two-member Stacks
This example shows how two switch stacks merge to form a stack.
  1. The first switch stack consists of two members: Switch-A and Switch-B.
    The second switch stack consists of members Switch-C and Switch-D with Switch-C as the stack master.
  2. When these two switch stacks are merged together, the election for  stack master occurs; let us consider that Switch-B wins the election.
  3. Switch-A will retain its stack member number.
  4. Switch-C and Switch-D will reload themselves and join the stack with new stack member numbers of "3" and "4" respectively.
    /image/gif/paws/71925/cat3750-7.gif
Tips to Add a Switch as a Slave to the Stack
Steps for adding a new switch on to the stack:
++ Issue the show switch detail command on the existing stack and find out the priority of each switch.
++ if all the switches are having priority 1, then it is possible that after a reload any switch can become the master.
To avoid this, increase the priority of the switch you want to be the master to 15. Backup master can be set as, giving priority to the next switch as 14.So master switch fails, then the back up switch will takeover as the master.
++ Change the new switch priority to 1.
++ Check the IOS version in the new switch, for a succesful formation stack all the switches should have the same image or you will get version mismatch error.
++ After ensuring, the new switch has the priority less than the master and the ios version is same as the other switches in the stack, save the configuration of the new switch and then power of the new switch.
++ Connect the stack cable of the new switch to the existing stack
++ If you issue show switch detail, you can see that whether the new switch has joined the stack or not.
Some useful commands:
show switch stack-ring speed
boot system switch 2 directory/filename.bin
show license all switch 1
session ---> this command will allow you to see the configurations in each switch.
Always the console you are seeing is of the master switch.
Hope this helps.
Cheers
Somu
Rate helpful posts
Thanks!!!
I will tray to add a slave switch to my stack!!!
