Forwarding Methods
trevorc1653
Frequent Visitor
Frequent Visitor
In the past, switches used either cut-through or store-and-forward switching as the forwarding methods
to switch data between network ports.  Although store-and-forwad is the sole forwarding method used
today on Cisco Catalyst switches, was there ever an IOS command that displayed the actual forwarding
method that was/is being used?
Thanks.
TLC
Joseph W. Doherty
Disclaimer
The  Author of this posting offers the information contained within this  posting without consideration and with the reader's understanding that  there's no implied or expressed suitability or fitness for any purpose.  Information provided is for informational purposes only and should not  be construed as rendering professional advice of any kind. Usage of this  posting's information is solely at reader's own risk.
Liability Disclaimer
In  no event shall Author be liable for any damages whatsoever (including,  without limitation, damages for loss of use, data or profit) arising out  of the use or inability to use the posting's information even if Author  has been advised of the possibility of such damage.
Posting
Don't recall a command for that.  If it's sometime that was on or off all the time, device datasheets should note.
I recall, years ago, some devices (might have been non-Cisco) that supported cut-through switching, might toggle it dynamically on-off depending on over all loading.
(BTW, some Nexus switches have re-introduced cut-through switch, believe it's limited to certain interfaces.)
