09-30-2011 03:49 AM - edited 03-07-2019 02:32 AM
Good morning everyone,
I searched on the bug toolkit for this issue but I did not find anything, so I wanted to post my experience on the forums (our support contract does not allow us to open a TAC case by ourselves).
I found a bug in Embedded Event Manager, on Catalyst 4500-E platform with supervisor V-10GE, on various IOS releases (in particular 12.2-50-SG IP BASE w/o crypto, 12.2-54-SG1 IP BASE w/o crypto, but also other releases included latest 15.0-2-SG1 ENTERPRISE SERVICES SSH).
The problem is that when you set up a EEM applet that monitors syslog pattern matching, and you also configure remote host logging *with* the option "sequence-num-session", when the match occurs, the switch reboots with message:
Sw (sometimes prints a number instead)
VECTOR D00
and in some cases performs a second reboot with message:
VECTOR 0
DOUBLE FAULT
The reload reason message is:
System returned to ROM by abort at PC 0x0
The problem does *not* occur if remote logging has not the option "sequence-num-session". I verified this behavior on various configurations (included our production 130K long *and* factory defaults after erase startup-config).
The configuration statements that cause reload are, for expample:
event manager applet prova
event syslog pattern %SYS-5-CONFIG_I
action 1.0 puts "configurazione modificata"
logging host 172.30.10.1 sequence-num-session
Hope this could be useful to someone, maybe this is a bug worth opening a case.
Massimo Malabotta
University of Trieste (Italy)
04-13-2013 03:25 PM
Today i did an upgrade Catalyst 4503-E from ipbase cat4500e-ipbasek9-mz.122-54.SG1.bin to cat4500e-entservicesk9-mz.151-2.SG.bin and when it finished, and everything was working fine, but suddenly when i put command exit from console putty terminal, switch reboot and i only saw this message:
VECTOR D00
Buffered messages:
*Apr 13 14:32:55.735: %SPANTREE-5-EXTENDED_SYSID: Extended SysId enabled for type vlan
000006: *Apr 13 09:32:59.107 PE: %SYS-5-CONFIG_I: Configured from memory by console
000007: *Apr 13 09:32:59.447 PE: %SYS-5-RESTART: System restarted --
Cisco IOS Software, Catalyst 4500 L3 Switch Software (cat4500e-ENTSERVICESK9-M), Version 15.1(2)SG, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2012 by Cisco Systems, Inc.
Compiled Wed 05-Dec-12 05:38 by prod_rel_team
000008: *Apr 13 09:32:59.663 PE: %SSH-5-ENABLED: SSH 2.0 has been enabled
000009: *Apr 13 09:32:59.875 PE: %SNMP-5-COLDSTART: SNMP agent on host SW-CORE-01 is undergoing a cold start
000011: *Apr 13 09:33:14.371 PE: %C4K_GLMMAN-3-X2PLUGGABLESEEPROMREADFAILED: Failed to read seeprom on port Te1/2. Reinsert X2 module or configure GigabitEthernet port group if TwinGigConverter is installed.
000012: Apr 13 16:42:39.488 PE: %SYS-5-CONFIG_I: Configured from console by GMD-soporte on console
Queued messages:
