Cisco 1941 with a switch
Mustapha Arakji
I have a Cisco router 1941 connected to a switch. Im configuring the wlan-ap and i need to have the wireless devices have an ip in the same range of the wired devices.
Since i cant use the same ip range on the gig0/1 and the Vlan 1 for the wireless, i wanted to know how to config the giga0/1 connected to the switch to act as a layer 2 port and i keep the ip on the vlan 1.
Hope i was clear in my query.
hi,
as leolaohoo said you need to configure router on a stick. Also if it's a 1941 wireless router you need to configure a bridge interface on your router to make it works.
Assuming you are connecting to the switch the port g0/1 of your router, you need to configure router interfaces in this way :
interface wlan-ap0
description Service module interface to manage the embedded AP
ip unnumbered BVI1
arp timeout 0
no mop enabled
no mop sysid
no shutdown
interface GigabitEthernet0/1
no ip address
duplex auto
speed auto
no shutdown
interface GigabitEthernet0/1.1
encapsulation dot1Q 1 native
bridge-group 1
interface Wlan-GigabitEthernet0/0
description Internal switch interface connecting to the embedded AP
switchport mode trunk
no ip address
interface Vlan1
no ip address
bridge-group 1
no shutdown
interface BVI1
description INSIDE LAN
ip address
no shutdown
exit
bridge 1 protocol ieee
bridge 1 route ip
let me know if you need help to configure embedded ap.
hope this helps.
regards
9 Replies 9
Leo Laohoo
You need to configure router-on-a-stick.
Sent from Cisco Technical Support Nintendo App
Mustapha Arakji
I configured giga0/1.1 with dot1q native vlan 1, with ip unnumbered vlan 1, or i should leave the interface without an ip.
Can i leave the switch port on the switch as access? I only have one vlan.
hi,
interface wlan-ap0
ip unnumbered BVI1
arp timeout 0
no mop enabled
no mop sysid
no shutdown
no ip address
duplex auto
speed auto
no shutdown
bridge-group 1
no ip address
interface Vlan1
no ip address
bridge-group 1
no shutdown
interface BVI1
ip address
no shutdown
exit
bridge 1 route ip
hope this helps.
regards
Mustapha Arakji
Thanks, configuration seems logical. I tried it but didn't work. I should configure the switch port connected to the router as trunk or should i leave it access?
Hi Mustapha,
Configure switch port in trunk mode.
What exactly is not working? Give us more details so we can better help you!
Mustapha Arakji
I could not ping ip address in the same range for PCs on the switch. The problem is that i don't have control on the switch. I will have to check with another team to make sure its trunk. I would expect that there is no configuration on the switch.
I will keep you posted. Appreciate the assistance.
Are you sure that embedded ap is configuredq properly?
Be sure that:
- wireless client can ping ap ip address
- wireless client can ping router ip address
Also check the default gateway configured for wirelss and wired clients
Mustapha Arakji
As suspected switch configuration. Once i changed the port to trunk things went fine. Everything was reachable. Once thing to mention is the DHCP. I have dhcp server in the same range but the wireless devices couldnt get an ip from it. I had to put ip helper address on the BVI interface of the AP To fix it.
Thank you guys for the advise.
Glad that i helped you!
