Frame Relay configuration example
fb_webuser
Level 6
Level 6
Do you have frame relay configuration example ?
Site to site where site A as Host and etc following site A use ISP media partner IP config DNS Server...
Posted by WebUser Janet Doe from Cisco Support Community App
Sruthi Pendam
Could you please throw more light on what kind of FR config you are looking for :
1) Point-to-point
2) Point-to-mulpoint
3) PPPoFR
However if you are striclty looking for any just basic config , following can help :
http://www.cisco.com/warp/public/125/14.pdf
This gives an idea how FR configuration is done.
Following link gives more indepth details about frame-relay configuration and troubleshooting :
http://www.cisco.com/en/US/tech/tk713/tk237/technologies_tech_note09186a008014f8a7.shtml
Hope this helps .
Sruthi Pendam.
fb_webuser
Level 6
Level 6
Check out these docs by Cisco
http://www.cisco.com/en/US/tech/tk713/tk237/tech_configuration_examples_list.html
Posted by WebUser Anamika Tiwari from Cisco Support Community App
Hello
please review this  post, its show how to setup a bacis frame-relay switch and configure a  hub& spoke point-to-multipoint connection
res
Pau;l
https://supportforums.cisco.com/message/3894967#3894967
Please don't forget to rate any posts that have been helpful.
Thanks.
Kind Regards
Paul
Sruthi Pendam
1) Point-to-point
3) PPPoFR
Hope this helps .
Sruthi Pendam.
sahseth
