Frame relay connections
support
I need some help with a home training lab.
I have a 1720 router with 2 56k csudsu wic cards and have a 2507 router with 16 port hub, I need to know if I can setup frame relay from the 56k wic cards to my 2507 router and if possible the steps needed to make it work. I have checked the internet and tried everything I could find with nothing working. Thanks for any help to make this work.
Steve Sisson
bwalchez
Level 4
Level 4
First enable frame-relay switching in global conf mode and then follow these steps,
int s0/0/0
encap frame-relay
frame-relay intf-type dce
clock-rate 64000
frame-relay lmi-type ansi
frame-relay route dlci interface (outgoing) dlci (outgoing )
no shut
wr
