frame relay maps
carl_townshend
Hi all, If I have a multipoint connection at site A, with a multipoint interface with various maps, on the spoke sites, can we just set it up on the serial interface and just use encap frame-relay, or do I have to map it ?
mihanlin
Hi Carl,
On the spoke router you will NOT have to map the IP address/DLCI of the hub router. However, if you have other spoke sites on the same subnet which you need direct connectivity to then these will have to be mapped statically.
Mike.
Cisco TAC.
can someone show me an example config for this ?
