Frame Relay Point to Multipoint with EIGRP
Theodore April
Good Evening All,
Need some help - Frame Relay Point to Multipoint with EIGRP
problem -
I'm able to connect / ping from SW1 to R2
I'm not able to ping or connect to R1
R1 is able to ping only as far as 10.0.0.1 which is the Gateway for SW1
Below is the config for Router 1
R1#sh run
Building configuration...
Current configuration : 1579 bytes
! Last configuration change at 19:42:52 EET Tue Apr 3 2018
version 15.2
service password-encryption
service compress-config
hostname R1
boot-start-marker
boot-end-marker
enable secret 5 $1$dTpN$VwjDKuuikkvKoa0voPAri/
enable password 7 060506324F41
no aaa new-model
clock timezone EET 2 0
no ip domain-lookup
ip cef
no ipv6 cef
spanning-tree mode rapid-pvst
vlan internal allocation policy ascending
interface Loopback0
interface Ethernet0/0
interface Ethernet0/1
interface Ethernet0/2
interface Ethernet0/3
interface Serial1/0
 no ip address
 shutdown
 no fair-queue
 serial restart-delay 0
interface Serial1/1
 no ip address
 encapsulation frame-relay
interface Serial1/1.1 multipoint
 ip address 192.168.0.1 255.255.255.248
 no ip split-horizon eigrp 1
 frame-relay map ip 192.168.0.2 102 broadcast
 frame-relay map ip 192.168.0.3 103 broadcast
 no frame-relay inverse-arp
interface Serial1/2
 no ip address
 shutdown
interface Serial1/3
 no ip address
 shutdown
router eigrp 1
 network 192.168.0.0 0.0.0.7
 network 192.168.1.0
ip forward-protocol nd
no ip http server
no ip http secure-server
control-plane
line con 0
 password 7 0822455D0A16
 logging synchronous
line aux 0
line vty 0 4
 password 7 045802150C2E
 login
 transport input all
end
Below is the config for Router 2
R2#
R2#sh run
Current configuration : 1628 bytes
! Last configuration change at 20:13:08 EET Tue Apr 3 2018
version 15.2
hostname R2
boot-start-marker
boot-end-marker
enable secret 5 $1$thDp$88jprJEaf/DtGguKRFcwA/
enable password 7 01100F175804
no aaa new-model
no ip domain-lookup
ip cef
no ipv6 cef
interface Loopback0
 ip address 192.168.2.1 255.255.255.0
 switchport mode access
 spanning-tree portfast edge
interface Serial1/0
 no ip address
 shutdown
 no fair-queue
interface Serial1/1
 no ip address
 shutdown
interface Serial1/2
 no ip address
interface Serial1/2.1 point-to-point
 ip address 192.168.0.2 255.255.255.248
 frame-relay interface-dlci 201
interface Serial1/3
 no ip address
 shutdown
interface Vlan1
 ip address 10.0.0.1 255.255.255.0
router eigrp 1
 network 10.0.0.0 0.0.0.255
 network 192.168.2.0
 passive-interface Vlan1
no ip http server
control-plane
line con 0
 password 7 00071A150754
 logging synchronous
line aux 0
line vty 0 4
 password 7 110A1016141D
 login
 transport input all
end
Below is the config for SW1
SW1#sh run
Current configuration : 1204 bytes
! Last configuration change at 20:13:07 EET Tue Apr 3 2018
version 15.2
hostname SW1
boot-start-marker
boot-end-marker
enable secret 5 $1$7eb.$J3brSO3bCtDBZiot3FEOP0
enable password 7 02050D480809
no aaa new-model
no ip domain-lookup
ip cef
no ipv6 cef
interface Vlan1
 ip address 10.0.0.2 255.255.255.0
ip default-gateway 10.0.0.1
no ip http server
control-plane
line con 0
 logging synchronous
line aux 0
line vty 0 4
 password 7 094F471A1A0A
 login
 transport input all
end
SW1#
Harold Ritter
The command "ip default-gateway 10.0.0.1" is only used if "ip routing" is disabled on the device. Your device has "ip routing enabled", hence it doesn't work. Try configuring a static default route instead:
ip route 0.0.0.0 0.0.0.0 10.0.0.1
Hi Harold ,
Thank you for your quick response
advise - disable ip routing
still not able to ping to Router1
something must be stopping my route on R2
see updated config
SW1#
SW1#
SW1#sh run
Current configuration : 1240 bytes
! Last configuration change at 23:28:04 EET Tue Apr 3 2018
version 15.2
hostname SW1
boot-start-marker
boot-end-marker
no aaa new-model
no ip routing
no ip domain-lookup
no ip cef
no ipv6 cef
interface Vlan1
 no ip route-cache
no ip http server
control-plane
line con 0
 logging synchronous
line aux 0
line vty 0 4
 login
 transport input all
end
SW1#
SW1#
SW1#
SW1#
SW1#ping 192.168.0.2
Sending 5, 100-byte ICMP Echos to 192.168.0.2, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/202/1004 ms
SW1#ping 192.168.0.1
Sending 5, 100-byte ICMP Echos to 192.168.0.1, timeout is 2 seconds:
Success rate is 0 percent (0/5)
SW1#
