03-16-2018 08:49 PM - edited 03-08-2019 02:17 PM
I will preface this with this is really my first venture in to the ISR space, and this is a lab machine I am working to learn on. The 2951 was originally a stand along machine, and I just received a refurb SM-D-ES3G-48-P that I installed.
The problem I am running in to is trying to configure the SM. It is installed, I have assigned an IP address, and I can get to the switch interface on GigabitEthernet2/0, however whenever I try to go in to privileged EXEC mode with enable, I just get Unknown cmd.
I have tried searching and following the step by step guide to setup the SM, but without being to get in to Privileged mode on the SM, there is not much I can do.
Solved! Go to Solution.
03-17-2018 12:16 PM
Have you loaded the image for the SM itself? How does your SM prompt look like?
Thanks for the reply.
Best regards,
Antonin
03-17-2018 12:16 PM
Best regards,
Antonin
04-03-2018 03:12 PM
Thanks for the reply. That was it, as it looks like the SM was not set to auto boot. Rookie move totally, but first time ever dealing with SMs.
