Frame-Relay
Hi!
I'm trying to put up a lab in GNS3 with Ipv6 and OSPFv3
I need to put up Frame-Relay.
So I have R1 connected to FRS port 1 DLCi 101 mapped to port 10 DLCI 202 To R2
R1 connected to FRS port 1 DLCi 102 mapped to port 11 DLCI 203 To R3
Config R1:
interface Serial0/0
no ip address
encapsulation frame-relay
ipv6 address 123::1/64
ipv6 rip R1R3 enable
ipv6 rip R1R2 enable
clock rate 2000000
frame-relay map ipv6 123::2 101 broadcast
frame-relay map ipv6 123::3 102 broadcast
no frame-relay inverse-arp
R2::
interface Serial0/0
no ip address
clock rate 2000000
interface Serial0/0.1 point-to-point
ipv6 address 123::2/64
frame-relay interface-dlci 202
R3::
interface Serial0/0
no ip address
clock rate 2000000
ipv6 address 123::3/64
frame-relay interface-dlci 203
They can ping each other
Problem is, I have R4 connected to Fa ports to both R2 and R3, and setup OSPF between them, so i can see all routes. But when I try to ping from R1 to R4 trafic does not form because of frame relay:
*Mar 1 00:21:45.167: Serial0/0:Encaps failed--no map entry link 79(IPV6).
How could I make this more dynamic so that traffic still gets through the Frame-Relay without explicitily mapping it to every IP addresses ?
Thanks!
3 Accepted Solutions
Hello
Thanks!
Hello
configure P2P sub interfaces on each router instead-
hub
int ser 0/0
enacap fr
int ser 0/0.12 point-to-point
ipv6 address xxxx:x
frame-relay interface dlci 102
nt ser 0/0.13 point-to-point
ipv6 address xxxx:x
spokes
int ser 0/0
enacap fr
int ser 0/0.21 point-to-point
ipv6 address xxxx:x
frame-relay interface dlci 201
res
Paul
Kind Regards
Paul
I finally found the issue.
Mappings and config was good, I just dforgot to map the link-local address to the multipoint interface.
Thanks for all!
Bonjour Jean-François,
I had explicitly stated that in my last post.
"You only need mapping for the next hop addresses, so in this case the link local address of R2 and R3, since you are using ripng to propagate the routes and that ripng uses the link local addresses rather than the global ipv6 addresses as the next hop address."
13 Replies 13
Hello
Thanks!
Hello
hub
int ser 0/0
enacap fr
ipv6 address xxxx:x
ipv6 address xxxx:x
spokes
int ser 0/0
enacap fr
ipv6 address xxxx:x
res
Paul
Kind Regards
Paul
In my book, Hub use only one IP and still gets full connectivity to all
Problem is, I don't have the config so I don't know how they do it
Hello
Humm...Even in IPV6 i am on the understanding depending on implementing FR on the Hub rtr on a  main interface or sub-interface you will still require either dlci mappings to each spoke or multiple p2p sub interfaces to each spoke.-  but I could be totally wrong.
I am curious to what book you are reading - can you share please -
res
Paul
Kind Regards
Paul
Harold Ritter
BonsoirJean-François,
Hello Harold
Can you clarify that please - i may have misinterpreted it  - when you say mappings your relating that to multipoint FR dlci mappings correct? if so my understanding is they then would still require mapping to/from hub and each spoke  apposed to P2P FR which doesn't map the dlci .
res
Paul
Kind Regards
Paul
Hi Paul,
Yes, that is correct. My statement was about the configuration that Jean-François is currently using on the hub site and would not be required if he was also using P2P subinterfaces at the hub site. My response was not about FR best practices either, but was more to help him fix the issue in the current config and also to explain some differences that are likely to be encountered when implementing IPv6.
Hello Harold
Thank you - very much appreciated
kind regards.
Kind Regards
Paul
So if my topology is as follow:
                     R1
             F-R                  F-R
             R2                         R3
               Fa0/0                   Fa0/0
                            R4
I need mappings of the IPs of R4 also?
It just doesn't make sense to me, it seems like a lot of static things.
Thanks again for your help!
Hello
For FR  and to limit DLCI mappings with R1 as you hub router , i would utilize FR P2P sub-interfaces
No you don't need mappings att all and especially for r4 as that isn't FR, you just need FR P2P statements on rtr1-2-3 and then advertise rtr 4 subnets in the IGP you are using
res
Paul
Kind Regards
Paul
As I indicated in my previous reply, R1 only needs mappings for R2 and R3 next hop, but not for R4. In fact, any destination behind R2 and R3 will use the mappings for R2 and R3.
You should make sure though that the mappings are for the appropriate next hops. Do a "show ipv6 route" and check what the next hops are for the ipv6 address of R4 and make sure that you add those in the mapping statements.
Harold
Thanks for all!
Yeah I haven't seen that portion.
Sorry and thanks again!
