Frame-Relay
HI.
I'm configuring the 1841 with QoS and a frame-relay link (512 k). The cloud is MPLS
I have 5 class of QoS.
With map-class with:
frame-relay cir 512000
frame-relay mincir 512000
frame-relay bc 5120
frame-relay be 0
frame-relay fragment 640
frame-relay adaptive-shaping becn
service-policy output Customer-NewPolicy
All class traffic data but voice class not.
Serial with map-class:
frame-relay mincir 256000
frame-relay bc 2560
frame-relay be 0
frame-relay fragment 320
All class traffic data and voice class too.
What's problem? The link isn't 512kbps?
Peterson
Kevin Dorrell
Level 10
Level 10
That looks strange, but it does look like you are exceeding your CIR. Feeding the traffic in at 512k, the provider seems to be dropping enough traffic to disturb your voice traffic. Is the provider quoting 512k CIR, or just the link?
The other thing is, what about the link on the other side of the cloud. Does that have sufficient bandwidth?
Kevin Dorrell
Luxembourg
Hi.
The another link have 8M and 2M to voice only!
