From 3750 to Nexus 9000 VTP Options
pablo.arcelcr
We are migrating our cores from Catalyst 3750 to Nexus 9000.
But we noticed that we can migrate the VLANS from teh catalyst 3750 to the Nexus since Nexus only has VTP transparent mode. Is there any other way that we can migrate the VLANs or change anything in the Nexus so we can enable the feature?
Any advise will be appreciated.
Reza Sharifi
By default, VTP is disabled on Nexus series switches.  If you want to use it you need to enable the feature.
"feature vtp"
BTW, I don't recommend using VTP at all.
In this case what you is your recommendation to migrate the VLANs that "lives" in the Catalyst 3750?
I already enable the vtp in Nexus but the only mode that it has is "Transparent"
My recommendation is to move the vlans manually from the old switch to the new one, configure them and verify connectivity.  I would turn off that feature in Nexus.
