FTP upload issue after new PPPoE router connection
pandapritam
I have bought a new 1921 router (IOS :C1900-UNIVERSALK9-M), Version 15.1(4)M4) and connect my ADSL link to it. After router connection i am facing frequent disconnection during uploading any file through coreFTP though i haven't face any problem in downloading any file from FTP server .
if i connect back the ADSL link directly to the PC there is no problem in uploading or downloading.
I have checked the MTU configuration on router and PC (Windows XP) still the same problem arises.
Please find my Router dialer and inside lan interface configuration.
interface Dialer0
description ++++ Dialer PPPoE interface_OUTSIDE ++++
ip address negotiated
no ip redirects
mtu 1492
ip tcp adjust-mss 1452
no ip unreachables
no ip proxy-arp
no ip mroute-cache
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
  ppp pap sent-username xxxxx password yyyyyyy
ppp ipcp dns request
ppp ipcp address accept
ppp ipcp route default
interface FastEthernet0/0/0
description ++++ Internet ADSL Link ++++
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
duplex auto
speed auto
pppoe enable group global
pppoe-client dial-pool-number 1
interface GigabitEthernet0/0
description ++++ Connected to LAN ++++
dampening
ip address 172.y.x.1 255.255.255.0
ip access-group filter in
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
ip virtual-reassembly
load-interval 30
carrier-delay msec 0
duplex auto
speed auto
Kindly suggest any work around. your prompt reply will be appreciated
Peter Paluch
I do not see any obvious issue with your configuration. This must be something quite minuscule. A couple of suggestions:
  • You are using the mtu 1492 command on Dialer0. Try replacing it with ip mtu 1492 command.
  • On your Dialer0 interface, remove the ip tcp adjust-mss command - it is already present in the Gi0/0 configuration.
  • In the ACL named "filter", make sure that all ICMP protocol messages are permitted.
Best regards,
Peter
Thanks a lot for you prompt reply.
I will do the changes and post the result
