Showing results forĀ
Search instead forĀ
Did you mean:Ā
DLSW circuit issue
desaisachin
Anyone knows the answer that we upgrade IOS and replaced module for 6509 but after that DLSW circuit is not being established. The connection is like We have router --> router  (Remote and local dlsw peer) then go to switch 6509 (which we replaced module and upgrade IOS and then go to HOST. Module replace has a lower version then the OLD module. Is this the issue for HW or SW.
jimmysands73_2
Level 5
Level 5
Can you provide a bit more info? Types of hw, sh runs on ints, sh int x/s outputs?
sreenath1987
Can you also give info of what is the IOS loaded ?
