FTP values
I installed a ftp server and doing the get and put session on this server from a laptop..but i need to find out the values like
number of bytes transferred, number of seconds it took and the kb/sec..i used filezilla to transfer data it is showing the number of bytes transferred by not the kb/sec..and it is not also doing the logging..can some body help me here
Karthik
Reza Sharifi
Hi Karthik,
You can take the bytes  value and divided it by 1000, that will give you kilobytes and if you take that number and divided by 1000, it will give you megabytes. For example
if you see 1000000 bytes divided this by 1000 is 1000 kilobytes and if you divide 1000 kilobytes by 1000, that will give you 1 megabyte
1000000/1000=1000 kb
1000/1000=1 mb
Reza
i am looking for how many kb it transferred per sec..i know how much data i am transferring but in how many seconds and what is kb/sec
