FW Upgrade on mixed 3750 Stack not working
bryan1981
Hi guys,
I have a mixed stack of 3750E and 3750G units. Max. feature level = ipbase.
With the Network Assistant I get an error when I try to upgrade the IOS.
I selected this file for the 3750: c3750-ipbaselmk9-tar.122-55.SE9.tar
and this file for the 3750E: c3750e-ipbasek9-tar.122-55.SE9.tar
When I try to run the upgrade this error shows up:
Uploading the image.
Uploading the image; this might take a few minutes/seconds...
Upgrading 3750 stack members
examining image...
extracting info (106 bytes)
extracting c3750-ipbasek9-mz.122-55.SE9/info (681 bytes)
Stacking Version Number: 1.45
System Type:             0x00000000
  Ios Image File Size:   0x00B8DA00
  Total Image File Size: 0x00C1C200
  Minimum Dram required: 0x08000000
  Image Suffix:          ipbasek9-122-55.SE9
  Image Directory:       c3750-ipbasek9-mz.122-55.SE9
  Image Name:            c3750-ipbasek9-mz.122-55.SE9.bin
  Image Feature:         IP|LAYER_3|SSH|3DES|MIN_DRAM_MEG=128
Error: The requested upgrade would bring some of the systems up to
Error: stacking version number 1.45.  The current stacking version
Error: number is 1.43.  Because not all of the systems are being
Error: upgraded, an incompatibility would result.  If this is really
Error: what you want to do, you have to specify the
Error: `/no-version-check' option to override this compatibility
Error: check.
Software upgrade failed.
When I try it with:
archive download-sw tftp://192.168.1.123/c3750e-ipbasek9-tar.122-55.SE9.tar  tftp://192.168.1.123/c3750-ipbaselmk9-tar.122-55.SE9.tar
I get this error:
Error: The image in the archive which would be used to upgrade
Error: system number 1 does not support that system type.
The current stack looks like this:
Switch Ports Model              SW Version            SW Image
*    1 30    WS-C3750E-24TD     12.2(53)SE            C3750E-UNIVERSAL-M
     2 30    WS-C3750E-24TD     12.2(53)SE            C3750E-UNIVERSAL-M
     3 12    WS-C3750G-12S      12.2(53)SE            C3750-IPBASE-M
     4 12    WS-C3750G-12S      12.2(53)SE            C3750-IPBASE-M
BTW: Lets say I have 2x 3750E and 2x 3750G in the stack. Is it possible to upgrade only 1 unit without having a downtime for the others?
Many thanks for your support!
amikat
There is a parameter "/destination-system stack-member-number" for the "archive download-sw" command which enables a stack member to be ugraded.
So provided you decide no to specify any other parameters your command sequence to upgrade your stack via CLI could read as follows:
archive download-sw /destination-system 1 /destination-system 2 tftp://192.168.1.123/c3750e-ipbasek9-tar.122-55.SE9.tar
archive download-sw /destination-system 3 /destination-system 4 tftp://192.168.1.123/c3750-ipbaselmk9-tar.122-55.SE9.tar
Good luck!
Best regards,
Antonin
