SG500X Inter VLAN Routing
Sundypha1
Hi there,
I've got a problem with VLAN routing.
First said, I'm new to VLAN's.
I've set up a Debian DHCP Server with following VLANS:
eth0      Link encap:Ethernet  HWaddr b8:27:eb:69:d0:18
          UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
          RX packets:360 errors:0 dropped:0 overruns:0 frame:0
          TX packets:139 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:1000
          RX bytes:28838 (28.1 KiB)  TX bytes:16833 (16.4 KiB)
eth0.1    Link encap:Ethernet  HWaddr b8:27:eb:69:d0:18
          inet addr:10.1.0.1  Bcast:10.1.15.255  Mask:255.255.240.0
          RX packets:0 errors:0 dropped:0 overruns:0 frame:0
          TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:0
          RX bytes:0 (0.0 B)  TX bytes:0 (0.0 B)
eth0.5    Link encap:Ethernet  HWaddr b8:27:eb:69:d0:18
          inet addr:10.105.100.1  Bcast:10.105.103.255  Mask:255.255.252.0
eth0.10   Link encap:Ethernet  HWaddr b8:27:eb:69:d0:18
          inet addr:10.110.100.1  Bcast:10.110.103.255  Mask:255.255.252.0
          RX packets:347 errors:0 dropped:0 overruns:0 frame:0
          RX bytes:26816 (26.1 KiB)  TX bytes:15165 (14.8 KiB)
eth0.15   Link encap:Ethernet  HWaddr b8:27:eb:69:d0:18
          inet addr:10.115.100.1  Bcast:10.115.103.255  Mask:255.255.252.0
eth0.20   Link encap:Ethernet  HWaddr b8:27:eb:69:d0:18
          inet addr:10.120.100.1  Bcast:10.120.103.255  Mask:255.255.252.0
          RX packets:5 errors:0 dropped:0 overruns:0 frame:0
          RX bytes:230 (230.0 B)  TX bytes:0 (0.0 B)
eth0.30   Link encap:Ethernet  HWaddr b8:27:eb:69:d0:18
          inet addr:10.130.100.1  Bcast:10.130.103.255  Mask:255.255.252.0
          RX packets:4 errors:0 dropped:0 overruns:0 frame:0
          RX bytes:184 (184.0 B)  TX bytes:0 (0.0 B)
lo        Link encap:Local Loopback
          inet addr:127.0.0.1  Mask:255.0.0.0
          UP LOOPBACK RUNNING  MTU:65536  Metric:1
and the switch configuration is the following: (shortened for the problems purpose)
switchcfd817#show running-config
config-file-header
switchcfd817
v1.3.0.62 / R750_NIK_1_3_647_260
CLI v1.0
set system queues-mode 4
file SSD indicator encrypted
ssd-control-start
ssd config
ssd file passphrase control unrestricted
no ssd file integrity control
ssd-control-end cb0a3fdb1f3a1af4e4430033719968c0
vlan database
vlan 2,5,10,15,20,30
exit
voice vlan id 15
voice vlan state disabled
voice vlan oui-table add 0001e3 Siemens_AG_phone________
voice vlan oui-table add 00036b Cisco_phone_____________
voice vlan oui-table add 00096e Avaya___________________
voice vlan oui-table add 000fe2 H3C_Aolynk______________
voice vlan oui-table add 0060b9 Philips_and_NEC_AG_phone
voice vlan oui-table add 00d01e Pingtel_phone___________
voice vlan oui-table add 00e075 Polycom/Veritel_phone___
voice vlan oui-table add 00e0bb 3Com_phone______________
ip dhcp relay address 10.110.100.1
ip dhcp relay enable
bonjour interface range vlan 1
hostname switchcfd817
re: <space>,  Quit: q or CTRL+Z, One line: <return> ip ssh password-auth                         : <return>
clock timezone " " 1
clock summer-time web recurring eu
ip domain polling-interval 18
 ip address 10.1.0.10 255.255.240.0
 no ip address dhcp
interface vlan 2
 name Admin
 ip address 10.102.100.10 255.255.252.0
interface vlan 5
 name Guests
 ip address 10.105.100.10 255.255.252.0
interface vlan 10
 name Server
 ip address 10.110.100.10 255.255.252.0
interface vlan 15
 name Voice
 ip address 10.115.100.10 255.255.252.0
interface vlan 20
 name Printer
 ip address 10.120.100.10 255.255.252.0
interface vlan 30
 name "Mechanical Engineers"
 ip address 10.130.100.10 255.255.252.0
interface gigabitethernet1/1/19
 switchport trunk allowed vlan add 10,20,30
interface gigabitethernet1/1/20
 switchport trunk native vlan 10
interface gigabitethernet1/1/25
 switchport mode access
 switchport access vlan 5
interface Port-channel1
 description data-syn-1
exit
macro auto built-in parameters printer $native_vlan 20
macro auto built-in parameters host $max_hosts 10 $native_vlan 1
With a client connected to a VLAN 30 or VLAN 10 port I get an IP from the DHCP, so DHCP relaying works.
Now the Problem:
I want to ping the DHCP Server on it's VLAN 10 IP 10.110.100.1 from VLAN 5 (static IP: 10.105.100.50 GW: 10.105.100.10)
this shows the routes automatically setup by the switch:
switchcfd817#show ip route
Maximum Parallel Paths: 1 (1 after reset)
IP Forwarding: enabled
Codes: > - best, C - connected, S - static,
       R - RIP
C   10.1.0.0/20 is directly connected, vlan 1
C   10.105.100.0/22 is directly connected, vlan 5
C   10.110.100.0/22 is directly connected, vlan 10
C   10.120.100.0/22 is directly connected, vlan 20
C   10.130.100.0/22 is directly connected, vlan 30
and the ARP list from the switch:
switchcfd817#show arp
Total number of entries: 2
  VLAN    Interface     IP address        HW address          status
vlan 5     gi1/1/25   10.105.100.50   00:80:80:8a:61:14   dynamic
vlan 10    gi1/1/19   10.110.100.1    b8:27:eb:69:d0:18   dynamic
I'm able to ping 10.110.100.10 (Switch on VLAN10) from VLAN 5 but not the DHCP Server.
What am I missing there?
best regards
Sundypha
Sundypha1
After mirroring port GE19 (DHCP Server) I see that the Switch is sending the ping packet to the DHCP Server. But without a VLAN Tag. So what do I have to do, to let the DHCP Server accept VLan10 as it's native? or better, to let the swtich tag the native vlan on a trunk interface to prevent double-tagged packets? And the Switch also does an ARP Request who has 10.110.100.1 despite it should know it in it's ARP Table.
