FW version upgrade for catalyst 7604
makabrahim
Mod Ports Card Type Model Serial No.
1 2 Supervisor Engine 720 (Active) WS-SUP720-3B SAL1014HU0M
2 48 CEF720 48 port 10/100/1000mb Ethernet WS-X6748-GE-TX SAL1205ESV8
Mod MAC addresses Hw Fw Sw Status
1 0017.5a34.f664 to 0017.5a34.f667 4.5 8.1(3) 12.2(33)SRB3 Ok
2 001f.6c89.40e0 to 001f.6c89.410f 2.7 12.2(14r)S5 12.2(33)SRB3 Ok
Mod Sub-Module Model Serial Hw Status
1 Policy Feature Card 3 WS-F6K-PFC3B SAL1014HTBB 2.2 Ok
1 MSFC3 Daughterboard WS-SUP720 SAL1014HUZ0 2.4 Ok
2 Centralized Forwarding Card WS-F6700-CFC SAL1204E8JR 4.0 Ok
Mod Online Diag Status
1 Pass
2 Pass
I need to upgrade cisco catalyst 7604 version from 8.1 to somewhat higher version like 8.4 or 8.5
Since at 8.1 version flash memory at internal slot is not supported.
So can you help me how can I upgrade this to required version.
Leo Laohoo
Exactly WHAT are you trying to upgrade?  The ROMmon or the IOS?
8.1(3) is the ROMmon/Bootstrap & 12.2(33)SRB3 is the IOS.
TAC usually recommends an IOS upgrade.
If this is the case, then you'll need to read the Release Notes very, very carefully because sometimes a ROMmon upgrade is mandatory before an IOS upgrade can follow.
Hi All
Thanks for your support.
I am able to upgrade Rommon version from 8.1 to 8.4.
At 8.1 version I had an issue CF is not detecting as bootable disk in internal slot of 720 supervisor card.
SO once I upgraded Rommon to 8.4 version,  720 supervisor board start taking CF as bootable disk at one of the internal RAM slot.
Br//
Rohit Gupta
