FWSM HA Context licenses
jacinto1m
I have an Active/Standbay pair of FWSM modules, do I need to license each or our FWSM modules?
For instance if I buy 50 context licenses for the active module, do I also have to buy 50 for the standby module?
Thanks.
Reza Sharifi
Yes, the license is per hardware.  Since you have 2 FWSM in 2 different devices, than you need 2 license.  The license is based in on the P/N and each device has a different P/N.
What about if I have both FWSM modules in the same device?
The same applies?
