Gateway IP issue
IrfanKhan4904
If someone has given a gateway IP and due to that some devices have internet but not others, how do we troubleshoot and reach the device that has been mistakenly given a gateway IP?
Blue_Bird
  • first of all... please confirm ...whether you network is implemented with  static ip or dynamic ip (dhcp)?
  • if it is static ip address...Open command prompt,  type ipconfig or  ipconfig /all to check whether it is assigned with gatway or not
  • if it is dynamic address....which device is playing dhcp server....your internet router or  any dedicated server....?
  • To prevent internet access for some users...you can configure some settings in the Router/server...
Best regards
******* If This Helps, Please Rate *******
Check by Traceroute
See the first hop appear
