Gateway
festusimazenobe
Community Member
Can a router act with 2 different gateways?
8 Replies 8
Marwan ALshawi
can u clearify ur question what kind of gateways and what connectivity u want ??
Edison Ortiz
A router can have 2 different default route/gateway on its configuration.
With this configuration, it will perform a 'per-session' load balancing towards both gateways.
In other words, a workstation may have a flow going towards gateway A and a different flow going towards gateway B.
HTH,
__
Edison.
hi Edison
really i liked this idea i havnt notced this
Hi Edison,
i have a server that i want to configure with two different pool of IPs with separate gateways, so i want to know if one router can be configured with the two different pool of IPs with separate gateways eg.(10.116.48.0/24 defaultgateway 10.116.48.1 and 10.116.49.0/24 defaultgateway 10.116.49.1)
festus.
it could be achived ethier by a secondary ip address on the router interface or by doing subinterfaces like router-on-stick
thanks
did u get it working ?
Are you trying to use the router as a DHCP server?
Are these 'pool of IPs' for DHCP ?
If so, yes - you can create different pool of IPs with different gateway/router information.
Please see:
http://www.cisco.com/en/US/docs/ios/ipaddr/configuration/guide/iad_dhcp_svr_cfg_ps6350_TSD_Products_Configuration_Guide_Chapter.html
on information regarding this subject.
HTH,
__
Edison.
