Gbic for cisco WS-C3750X-24P-S
Hi All,
          If you have some idea or what exactly model GBIC  cisco WS-C3750X-24P-S because as off now im searching what specific model.
Kindly find my attachment file.
I hope to help me this community.
Thanks Advances.
Erwin
Leo Laohoo
Go HERE.
Glenn Martin
Moving post to appropriate community: Network Architecture>LAN, Switching and Routing
devils_advocate
Level 7
Level 7
Assuming you are just going to be connecting those switches together as per the attached image, I would suggest you need two of the following:
Cisco 1000BASE-SX SFP
This assumes you are going to use a multimode fibre patch cable.
If you are happy to use copper then you could also use two of the following:
1000BASE-T
FYI - The 3750x series is a heavy switch so I would make sure all 4 screws are in and securely done up :)
