Gbic port unusable
error massage:
POST: Inline Power Controller Tests : Begin
POST: Found inline power controller write failure, inst 0
POST: Inline Power Controller Tests : End, Status Failed
Gbic port not functions.
why this happen coz of hardware or software?
lgijssel
Level 9
Level 9
Too bad; POST-failures are mostly hardware.
Leo
I've got the same issue. To be more specific I found that i went into this issue only when, in a 3560-24P, i insert both sfp.
If i insert only one of them all is working fine
Had You any news ?
regards
Luigi
In enable mode, try the command "show post". The results should be "End, Status Passed". If the result comes back as "failed" then you need to RMA the switch.
