General Network Infrastructure Help
chrs944
Community Member
I'm setting up a new network.
There will be 4 WS-C3750E-48PD-SF 48 Port switches for workstation / voip access
There will be 2 WS-C3750E-24TD-S 24 Port switches for server access.
I need a recommendation for a core switch. Since the switches listed above have 10G uplink ports, I was hoping to find a switch that has 10G ports. Obviously I would purchase 2 core switches and connect an uplink from each of the above switches to its own port on each of the core switches so each core switch would need 6 ports at minimum.
I also have a questions about router vs. firewall.
My plan is to setup a VPN so I was looking at the ASA5525-x.
Would this be sufficient for client VPN access? I'm not so much concerned with having site to site access. What client software does the ASA5525-x support, is it Cisco client only? do I need a license for each client?
Would the ASA5525-x be sufficient to also serve as a router? We aren't doing anything extreme when it comes to routing. Maybe a few NAT rules to one or 2 servers.
Reza Sharifi
For core switches, you can use a set of 16 port 4500x switches. If you configure them as VSS, you have 2 physical devices but you manage only one logical device and no need for HSRP, VRRP, etc..
All 16 ports are fiber and can be gig or 10Gig.
As for your second questions, you can use the ASA for VPN access. Your users need to download the Cisco VPN client or if you have an AD environment, it can be pushed to their devices using a GPO. Not sure how many licenses the  ASA comes with but you may have to purchase some.
Thanks for the reply.
I'm on a pretty tight budget so I want to try and avoid the 4500x switches. What do you think about the WS-C3560E-12D-E ? I should be able to use these and then get the X2-10GB-LR modules along with some SC-SC single mode fiber correct?
Also, apart from using the ASA for VPN connections, can it also serve as a router or will I need to get a separate device for that? The routing is simple, just some NATing
