Get informations by switch about IP CAMERA
Hello All,
I would like to get information like temperature of Camera IP by SWITCH, so I would like to know what are the commands should put in the switch to get All the informations about my neighbour?
Thanks for helping
Mark Malone
Switch will unlikely read a 3rd party cameras temperature , if the camera understands LLDP you will receive some information regarding it
You can turn it on globally in global config on the switch with lldp run
If its a cisco camera use cdp run
You can get the temperature of the switch alright with sh environment
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst2960/software/release/12-2_37_ey/configuration/guide/scg/swlldp.pdf
I don't think you can get that much detail from the switch, you would need to poll the IP camera through SNMP, and a switch cannot really be an SNMP polling device.
Have a look at the below list of SNMP management software:
https://www.capterra.com/sem-compare/network-monitoring-software?gclid=Cj0KCQiA-JXiBRCpARIsAGqF8wWWjSIY-huAgSqUwNRBJ9w6UGEf3PT4ig8QHbnmTRiJ-Qpq3nSK4FwaAt_-EALw_wcB&gclsrc=aw.ds
Mark Elsen
 - The switch does not have that capability ; if your device can be queried by SNMP ; there might a  MIB that  provides those info's.
M.
Can you give me an example to put the command in the switch plz ?
