Get Port Info by PC Name remotely
seanym071703
we used to have a way (vbs script, or bat file believe) (Get-Port, was the command I think), its been awhile since needing it, to pull the port information of a windows device, by name. there were two commands, either by single device name, or by multiple names, if a list was provided via txt. After the command, it would spit out individual text files by the device name to a patch/dir that I would identify in the script. I can no longer find this tool we used, as I must of deleted by mistake.
does anyone have same or similar script to do this?
Nadav
Level 7
Level 7
If you're not looking to locate the device on the network, but just collect information for a specific IP/hostname, check this if the endpoint is in AD:
https://social.technet.microsoft.com/Forums/en-US/059a32bb-bf87-4b84-b9a7-9955ae5b9e0f/using-powershell-pc-names-amp-ip-addresses?forum=w7itprogeneral
There are security concerns for allowing WMI to run remotely, but that's up to your admins.
