12-25-2013 08:20 AM - edited 03-07-2019 05:14 PM
I want to check the details of the Gigabit autonegotiation on Catalyst switches.
Please teach me the debug commands that can check the details of the negotiation of duplex and flow control.
Thank you for your cooperation in advance.
12-25-2013 08:45 AM
This command will show you what the duplex, speed, and type is negotiating to for every interface
switch#sh int status
OR
To show you details about the interface in question use this command where the "x" is the interface number.
switch#sh int gix/x/x
12-25-2013 02:48 PM
You have several commands:
1. sh interface
2. sh interface
However, this is totally irrelevant because fibre optics only have one speed (100 Mbps, 1 Gbps or 10 Gbps) and full duplex.
The speed is totally dependent on the type of SFP module. Current Cisco SFP do not support multi-speed.
12-26-2013 02:20 AM
dbrowning88-san and Leo Laohoo-san:
Thank you for your answers.
However, these commands show the results of the negotiation.
I want to check the sequence details of the Gigabit autonegotiation.
