Unable to ping from spoke to spoke as already disable split horizon on Hub
Sanjib Pradhan
Hii..Team,
I have a very small diagarm. R1 acts as Hub and R2,R3 are spoke. Two PVC already enabled between R1-R2(102,201) and R1-R3(103,301). I have configured RIP among all devices. Currently I am unable to ping from R2's loopback address to R'3 loopback address as already disable split horizon on
R1's serial interface.
Please find below output.
R1#sh frame-relay map
Serial0/0 (up): ip 10.1.1.2 dlci 102(0x66,0x1860), dynamic,
              broadcast,, status defined, active
Serial0/0 (up): ip 10.1.1.3 dlci 103(0x67,0x1870), dynamic,
R1#sh ip route
Gateway of last resort is not set
     2.0.0.0/24 is subnetted, 1 subnets
R       2.2.2.0 [120/1] via 10.1.1.2, 00:00:17, Serial0/0
     3.0.0.0/24 is subnetted, 1 subnets
R       3.3.3.0 [120/1] via 10.1.1.3, 00:00:16, Serial0/0
     10.0.0.0/24 is subnetted, 1 subnets
C       10.1.1.0 is directly connected, Serial0/0
R2#sh ip route
C       2.2.2.0 is directly connected, Loopback1
R       3.3.3.0 [120/2] via 10.1.1.3, 00:00:16, Serial0/0
R3#sh ip route
R       2.2.2.0 [120/2] via 10.1.1.2, 00:00:16, Serial0/0
C       3.3.3.0 is directly connected, Loopback1
R1#sh ip int s0/0
Serial0/0 is up, line protocol is up
  Internet address is 10.1.1.1/24
  Broadcast address is 255.255.255.255
  Address determined by setup command
  MTU is 1500 bytes
  Helper address is not set
  Directed broadcast forwarding is disabled
  Multicast reserved groups joined: 224.0.0.9
  Outgoing access list is not set
  Inbound  access list is not set
  Proxy ARP is enabled
  Local Proxy ARP is disabled
  Security level is default
  Split horizon is disabled
  ICMP redirects are always sent
  ICMP unreachables are always sent
R2#ping 3.3.3.3 source l1
Sending 5, 100-byte ICMP Echos to 3.3.3.3, timeout is 2 seconds:
Packet sent with a source address of 2.2.2.2
Success rate is 0 percent (0/5)
Please help me!!!!!!
Sanjib Pradhan
Diagram....
the next-hops of the RIP-routes point to the other spoke's IP-addresses (not to the hub!) and most probably the spokes do not have mappings for the other spoke's IPs.
http://www.cisco.com/en/US/tech/tk713/tk237/technologies_tech_note09186a008014f8a7.shtml#connectspoketospoke
Rolf
Dear Rolf,
But in case of Eigrp it's pinging without PVC between spoke to spoke. Why it is required to configured the PVC between spoke to spoke, Already routes learned by RIP(Split horizon disable on R1).
Sanjib
Sanjib,
this is actually a layer-2 problem.
The hub router and the two spokes share a common network: 10.1.1.0/24
So RIP assumes that every attached host can communicate with each other directly - which would be true with Ethernet, for example.
However, in a Frame-Relay hub and spoke topology, the spokes normally only have layer-2 information to reach the hub.
Some routing-protocols have built-in solutions to overcome this (layer-2) limitation, e.g. OSPF injects host-routes when the network-type is point-to-multipoint. At the moment I can't recall how EIGRP deals with that, but I would assume that it sets the next-hop IP as the hub, not the other spoke.
Rolf
