Gigabit Fiber Card compatibility
tecboxuser
Could someone tell me if the following configuration will work?
Gigabit Fiber NIC card in server connecting to a Gigabit Switch (Cisco Catalyst-6513 w/ WS-X6516-GBIC module) which connects to the primary 10/100 Switch.
Thanks.
Kevin Dorrell
Level 10
Level 10
Yes, that will work, but make sure you have the same flavour of Gigabit fiber in the NIC and the GBIC. Usually for a server NIC it will be 1000BaseSX.
Kevin Dorrell
Luxembourg
