GIgastack flow control
gobigblue
I have a few 3548's connected using gigastack connectors. They are using asymmetric flow control on the gigstack modules. Is there a recommended setting for this or should I just turn the flow control off all together.
iyde
Level 4
Level 4
Why would you want to change it - or even more, why remove it? Flow control is there exactly to do what it is called: Control the flow.
For the XL switches like yours you should be aware that if you stack more than two switches together, your stack connection will be half duplex.
HTH.
