Help:Why I can ping host1 and but not host2;same network.
news2010a
Level 3
Level 3
My client (network 192.168.1.0/24)----------[RouterA]-----Layer 3 switch----2950 switch (host1,host2)
from my client, I can ping host1. Host1 IP=11.2.53.104/26
from my client, ping to Host2 IP=11.2.53.105/26 times out.
From Layer3Switch and 2950 I can ping Host2 just fine.
I did trace from client and the traffic to Host2 dies on RouterA.
On RouterA, I confirm that I can ping Host1 OK and Host2 times out.
I examine access-lists existing there, but I can't see any that would allow 11.25.3.104/26
and it would block 11.2.53.105/26.
Question:
Any ideas on how I troubleshoot this further?
8 Replies 8
Lucien Avramov
Level 10
Level 10
debug ip icmp on the router A
Try to ping host2 and see if the icmp is sent.
Do also a show ip route 11.2.53.105 on your router A and post the output.
It sounds like either an ACL issue, or Router A does not have a route to host 2.
On RouterA, I did it and route is present for host2. Same route is shown for host1.
Then using the below, I used cdp neig detail and got to a switchX. From switchX, ping to host2 also times out.
Trace from switchX goes to Layer3switch via trunk. I can't see anything wrong on the trunk. From Layer3Switch I can ping host2 as informed earlier.
RouterA#show ip route 11.2.53.105
Routing entry for 11.2.53.96/27 (before I said it was /26, but it is /27. Host is mask is /27 OK).
Known via "ospf 1", distance 110, metric 2020, type intra area
Last update from 10.2.55.233 on FastEthernet0/0.32, 1d00h ago
Routing Descriptor Blocks:
* 11.2.55.234, from 11.2.255.1, 1d00h ago, via FastEthernet0/0.32
Route metric is 2020, traffic share count is 1
11.2.55.233, from 11.2.255.1, 1d00h ago, via FastEthernet0/0.32
11.2.53.13, from 11.2.255.1, 1d00h ago, via FastEthernet4/0.19
11.2.55.226, from 11.2.255.1, 1d00h ago, via FastEthernet1/1.31
from l3 switch, try to ping host 2 with a source interface: the one that connects to router A.
If that ping fails, host 2 doesnt have a route to router A subnet.
I did the extended ping using host2 and source address of Layer3Switch which connects to RouterA and that fails. Host1 works.
So it sounds this would be a host configuration problem?
I already checked on the 2950switch the host is connected to and the ip-default gateway is correct.
okay that is what I thought, that means host2 does not have a route to the subnet that is between layer3switch and router.
You can either configure a default route in host2 or define a default gateway. Most likely if its a linux it knows only about its own subnet by default.
Configure your host properly and then your issue should be fixed.
The ip default-gateway configured on the 2950 is the default gateway for management access to that particular switch. It has nothing to do with the end-client default gateway.
PETER EIJSBERG
Did you check the default gateway on host2?
That sound like a default gateway problem in host 2. Make sure Host 2 has the same mask and gateway as host 1.
