GLBP dest mac - not able to understand
chid_1989
i configured a basic topology as following.
F1/0 in R1 is 1.1.1.1/24 and F1/0 in R2 is 1.1.1.3/24. R2 is the AVG.
In R2, 0007.b400.0101 is the AVF and 0007.b400.0102 is in listen state. in R1 it is the vice versa.
Now from host C1, i pinged C2, for which i got one dest mac for arp reply 00:07:b4:00:01:01 ( which is the AVF in R2 )
from C4 i pinged C2, for which i got 00:07:b4:00:01:02 ( which is the AVF in R1 )
but what is happening is, for the arp and further icmp replies , it is using the dest mac in the ethernet frame and sending to the same router ( R2 ). It is not load balancing. What could be the problem here.
Chidambaram
6 Replies 6
Hi Chidambaram,
First of all the AVG is responsible for answering ARP requests for the virtual IP address. Load sharing is achieved by the AVG replying to the ARP requests with different virtual MAC addresses.
I can assume that if you are using GLBP on the other side , the AVF for C2 is R2
Dan
Hi Dan,
Thanks for the reply.
Ya, the AVG replied for the ARP with 2 different dest macs. Also the AVF for C2 is R2. but my concern, why is it putting the dest mac as the mac of the i/f of r2. it should put the dest mac as the glbp mac right? Since it is putting the i/f mac, it is not going to both the routers. Or may be i can put it like this. I am not clear still
attached my pkt capture
if you see in the icmp req's , the dest mac is the interface mac opposed to what shuld have been glbp mac.
Chidambaram
Chidambaram,
Could you please check the default route of the C4 , because If I'm not mistaken in your capture , just before transmiting ICMP request you have ARP request for 1.1.1.2 , not for 1.1.1.1 which is the Virtual Gateway. Correct my if I'm wrong the glbp ip is 1.1.1.2.
Dan
Dan,
Yes, 1.1.1.2 is been configured as the default gateway in the hosts. I have a basic doubt. Shouldn't the dest mac be the glbp mac in the packets. Why is the dest mac, mac of the interface
Hi Chidambaram,
Yes you are right the destination mac must be the virtual mac address.
Dan
Thank you for clearing that doubt. I think there should be some prob in the host ( sim ). Because in the repsonse from the routers, it is sending different macs. I guess the host picks the wrong mac. i will replace the hosts with routers and try. Thanks very much for replying.
Chidambaram
