GLBP issues with a new SVI
ALIAOF_
Level 6
Level 6
I have two 4948E's configured with GLBP and and they have been working fine.  I configured another SVI with GLBP config and when I do "show glbp vlan 120" I see that both switches are Active and the group member only shows the local switch.  Any ideas will be appreciated:
Switch 1:
interface Vlan120
description "Development Network"
ip address 10.1.120.2 255.255.255.0
glbp 120 ip 10.1.120.1
glbp 120 priority 110
glbp 120 preempt
glbp 120 weighting 5
glbp 120 load-balancing weighted
glbp 120 authentication md5 key-string 7 xxxxxxxxxxxxxxxxx
glbp 120 weighting track 120 decrement 20
Vlan120 - Group 120
  State is Active
    1 state change, last state change 01:29:49
  Virtual IP address is 10.1.120.1
  Hello time 3 sec, hold time 10 sec
    Next hello sent in 0.352 secs
  Redirect time 600 sec, forwarder timeout 14400 sec
  Preemption enabled, min delay 0 sec
  Active is local
  Standby is unknown
  Priority 110 (configured)
  Weighting 5 (configured 5), thresholds: lower 1, upper 5
    Track object 120 state Up decrement 20
  Load balancing: weighted
  Group members:
    a493.4cda.587f (10.1.120.2) local
  There is 1 forwarder (1 active)
  Forwarder 1
    State is Active
      1 state change, last state change 01:29:38
    MAC address is 0007.b400.7801 (default)
    Owner ID is a493.4cda.587f
    Redirection enabled
    Preemption enabled, min delay 30 sec
    Active is local, weighting 5
Switch 2:
interface Vlan120
ip address 10.1.120.3 255.255.255.0
glbp 120 preempt
glbp 120 weighting 6
glbp 120 authentication md5 key-string 7 xxxxxxxxxxxxxxxxxxxxxxxx
end
Vlan120 - Group 120
  State is Active
    1 state change, last state change 01:13:27
    Next hello sent in 0.096 secs
  Authentication MD5, key-string
  Active is local
  Standby is unknown
  Priority 100 (default)
  Weighting 6 (configured 6), thresholds: lower 1, upper 6
  Group members:
    a493.4cdb.10ff (10.1.120.3) local
  Forwarder 1
    State is Active
      1 state change, last state change 01:13:15
    Owner ID is a493.4cdb.10ff
    Redirection enabled
    Active is local, weighting 6
ALIAOF_
Level 6
Level 6
An update for some reason I can not ping the IP address of the SVI's from the switches.  I have the following on the two switches:
Switch 1:
spanning-tree vlan 1,5,9,48,200,250 priority 24576
Switch 2:
spanning-tree vlan 1,5,9,48,200,250 priority 28672
Would this be an issue I need to add VLAN 120 to this as well?
Well figured it out yes that was the issue.  New VLAN needs to also go into that statement.
spanning-tree vlan 120 priority 24576 (Primary)
spannig-tree vlan 120 priority 28672 (Secondary)
I just ran those two commands on the switches primary and secondary and all is working now.  Note:  that command appended to the existing did not overwrite it.
