GLBP not working on ASR920
kimfrellsen
I am trying to configure GLBP on a BDI in an ASR 920 with IOS XE SW 3.16.
The configuration is accepted but it is not applied to the router. I have also tried to configure GLBP directly on a Gi interface with same result.
Is GLBP not working in ASR920 or am I doing something wrong?
interface BDI1100
 vrf forwarding myvrf
 ip address 10.11.11.2 255.255.254.0
 encapsulation dot1Q 1100
end
R2#conf t
Enter configuration commands, one per line.  End with CNTL/Z.
R2(config)#inte bdi 1100
R2(config-if)#glbp 10 ip 10.11.11.1
R2(config-if)#^Z
R2#show run inte bdi 1100
Building configuration...
interface BDI1100
end
egiron2005
I do not think this feature was included on IOS XE, I would like to have it too
egiron2005
Correct. I found out that GLBP was not included in IOS XE unfortunately.
jpeach
Check out the GLBP config guide and feature Navigator -
 GLBP Config Guide:   This lists some restrictions but nothing about IOS EX or ASR920’s
https://www.cisco.com/c/en/us/td/docs/ios-xml/ios/ipapp_fhrp/configuration/xe-3s/fhp-xe-3s-book/fhp-glbp.html
However we have experience a similar problem so I could do with Cisco (TAC or Cisco representative) or someone who's has some experience of this to definitively state if there either is or isn't (?) support for GLBP support on a 10G interface between two ASR920's.
