01-21-2022 07:15 AM
Have anyone tested getting GLC-GE-100FX working on NM-4G in a Cat 9200? Have tried with ver 16.12.4 and 17.3.4b.
In both cases show inventory looks a bit strange: No PID is read from the SFP
switch#show inventory
NAME: "c92xx Stack", DESCR: "c92xx Stack"
PID: C9200-24P , VID: V01 , SN: JAE2518079J
NAME: "Switch 1", DESCR: "C9200-24P"
NAME: "Switch 1 - Power Supply A", DESCR: "Switch 1 - Power Supply A"
PID: PWR-C6-600WAC , VID: V01 , SN: ART2509F236
NAME: "Switch 1 FRU Uplink Module 1", DESCR: "4x1G Uplink Module"
PID: C9200-NM-4G , VID: V02 , SN: JAE25160SKQ
NAME: "Gi1/1/4", DESCR: "100BaseFX SFP"
PID: , VID: , SN: OPC10092039
The switch recognize the SFp but it takes about 20sec before it's registered on the interface. Stick in a GLC-SX-MM and it's registered after 5sec
The problem I have is that I never get link up. Tried with auto speed and duplex, auto speed and full duplex and speed 100 and full duplex. No link. No matter what is in the remote end (Cat2960x, C9200 or IE3200)
On a Cat 2960 one can insert the SFP withn auto speed and duplex and the link comes up half-duplex. Or set duplex to full and that works fine as well.
If I try the SFP model in a Cat 2960x it lists the SFP with pid.
C2960X# show inventory
NAME: "1", DESCR: "WS-C2960XR-24TS-I"
PID: WS-C2960XR-24TS-I , VID: V06 , SN: FDO2133B03L
NAME: "Switch 1 - Power Supply 1", DESCR: "FRU Power Supply"
PID: PWR-C2-250WAC , VID: V03L , SN: LIT21283MYE
NAME: "Switch 1 - Power Supply 2", DESCR: "FRU Power Supply"
PID: PWR-C2-250WAC , VID: V03L , SN: LIT21132GEE
NAME: "Switch 1 - FlexStackPlus Module", DESCR: "Stacking Module"
PID: C2960X-STACK , VID: V02 , SN: FDO212520N9
NAME: "GigabitEthernet1/0/25", DESCR: "100BaseFX SFP"
PID: GLC-GE-100FX , VID: v01 , SN: OPC10092039
Diff between interface on Cat 9200 and C2960X with the SFP inserted and the only command set is "duplex full"
# Cat9200
GigabitEthernet1/1/4 is down, line protocol is down (notconnect)
Hardware is Gigabit Ethernet, address is bcd2.95cd.301c (bia bcd2.95cd.301c)
MTU 1500 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
Keepalive not set
Full-duplex, 100Mb/s, link type is force-up, media type is 100BaseFX SFP
input flow-control is on, output flow-control is unsupported
# Cat 2960X
GigabitEthernet1/0/25 is down, line protocol is down (notconnect)
Hardware is Gigabit Ethernet, address is 701f.53a6.7199 (bia 701f.53a6.7199)
MTU 1500 bytes, BW 100000 Kbit/sec, DLY 100 usec,
Keepalive not set
Full-duplex, Auto-speed, link type is auto, media type is 100BaseFX SFP
input flow-control is off, output flow-control is unsupported
Any ideas on port settings?
02-21-2024 10:23 PM
Just commenting in case anyone else has this issue. The matrix does show support for GLC-FE-100FX but has a note on it saying that they must be GLC-FE-FX be version 02 and not version 01. The output shown in Sokarlsson's has the VID as V01 so I expect that may be the issue. Did you resolve this, Sokarlsson?
02-22-2024 02:02 AM
Good catch, @Ric Beeching (Cisco).
