GLC-LH-SMD working with GLC-LH-SM
Atul Pawar
Hi All,
  Is it OK to have a GLC-LH-SMD at one end and GLC-LH-SM at the other end of the fibre? I couldn't find any information so would appreciate if someone can confirm that this supported and there are no known issues.
Cheers
Atul
Steve Fuller
Level 9
Level 9
Hi Atul,
Both the GLC-LH-SM and GLC-LH-SMD transceivers support the IEEE 802.3 1000BASE-LX/LH standard and so are compatible with each other. The difference between the two is that the GLC-LH-SMD transceiver has additional support for Digital Optical Monitoring capability.
Steve Fuller
Level 9
Level 9
Hi Atul,
Thanks Steve
