08-20-2014 03:37 PM - edited 03-07-2019 08:28 PM
I noticed that some Cisco GLC-T stay definitely in a down status on Nexus5548 (System version: 6.0(2)N2(1)).
To test, the basic configuration is :
interface ethernet 1/7
speed 1000
switchport mode trunk
I have 4 different versions of Cisco GLC-T (different electronic boards) that I used on this interface. 2 of them stay down.
Note: On C4500-X, no problem.
You'll find my test in attachment (Unfortunetely, I have no pictures of the 4th)
Software or hardware issue ? Can someone confirm ?
Herve
08-20-2014 04:11 PM
Look at the hardware revision number. It's is normally a set of numbers in this syntax: XY-ABCD-NN.
The "NN" is what you are looking for. This is the hardware revision number.
08-21-2014 02:48 AM
The revision number is 03 for all the GLC-T tested.
