GLC-T error SFP validation failed on Nexus 5548
sachin.sg
We inserted GLC-T modules and on Nexus 5548 they are showing SFP validation Failed  , as per Cisco doc GLC-T is support . Can any one help me out in fixing this , since we have 28 such modules and all after inserting showing same error. please see the below details.
I also try configuring speed and inserting modules but no result ..
Please let me know whether my GLC-T module is supported on Nexus 5548
INMUMFDS1SWCORE01# show module
Mod Ports  Module-Type                      Model                  Status
1    32     O2 32X10GE/Modular Supervisor    N5K-C5548P-SUP         active *
2    16     O2 16X10GE Ethernet Module       N55-M16P               ok
3    0      O2 Daughter Card with L3 ASIC    N55-D160L3             ok
Mod  Sw              Hw      World-Wide-Name(s) (WWN)
1    5.0(3)N2(1)     1.0     --
2    5.0(3)N2(1)     1.0     --
3    5.0(3)N2(1)     1.0     --
INMUMFDS1SWCORE01# show int brief
Ethernet      VLAN   Type Mode   Status  Reason                   Speed     Port
Interface        Ch #
Eth1/1        1      eth  trunk  up      none                        10G(D) 10
Eth1/2        1      eth  trunk  up      none                        10G(D) 10
Eth1/3        1      eth  fabric up      none                        10G(D) 100
Eth1/4        1      eth  fabric up      none                        10G(D) 101
Eth1/5        1      eth  trunk  up      none                        10G(D) --
Eth1/6        1      eth  trunk  up      none                        10G(D) --
Eth1/7        1      eth  access down    Link not connected          10G(D) --
Eth1/8        1      eth  access down    Link not connected          10G(D) --
Eth1/9        1      eth  access down    Link not connected          10G(D) --
Eth1/10       1      eth  access down    Link not connected          10G(D) --
Eth1/11       1      eth  access down    Link not connected          10G(D) --
Eth1/12       1      eth  access down    Link not connected          10G(D) --
Eth1/13       1      eth  access down    Link not connected          10G(D) --
Eth1/14       1      eth  access down    Link not connected          10G(D) --
Eth1/15       1      eth  trunk  up      none                        10G(D) --
Eth1/16       1      eth  access down    Link not connected          10G(D) --
Eth1/17       902    eth  access down    SFP not inserted            10G(D) --
Eth1/18       1      eth  access down    SFP not inserted            10G(D) --
Eth1/19       1      eth  access down    SFP not inserted            10G(D) --
Eth1/20       1      eth  access down    SFP not inserted            10G(D) --
Eth1/21       1      eth  access down    SFP not inserted            10G(D) --
Eth1/22       1      eth  access down    SFP not inserted            10G(D) --
Eth1/23       1      eth  access down    SFP not inserted            10G(D) --
Eth1/24       1      eth  access down    SFP not inserted            10G(D) --
Eth1/25       1      eth  access down    SFP not inserted            10G(D) --
Eth1/26       1      eth  access down    SFP not inserted            10G(D) --
Eth1/27       1      eth  access down    SFP not inserted            10G(D) --
Eth1/28       1      eth  access down    SFP not inserted            10G(D) --
Eth1/29       1      eth  access down    SFP not inserted            10G(D) --
Eth1/30       1      eth  access down    SFP not inserted            10G(D) --
Eth1/31       1      eth  access down    SFP not inserted            10G(D) --
Eth1/32       1      eth  access down    SFP not inserted            10G(D) --
Eth2/1        902    eth  access down    SFP validation failed      1000(D) --
Eth2/2        1      eth  access down    SFP validation failed       10G(D) --
Eth2/3        1      eth  access down    SFP validation failed       10G(D) --
Eth2/4        1      eth  access down    SFP validation failed       10G(D) --
Eth2/5        1      eth  access down    SFP validation failed       10G(D) --
Eth2/6        1      eth  access down    SFP validation failed       10G(D) --
Eth2/7        1      eth  access down    SFP validation failed       10G(D) --
Eth2/8        1      eth  access down    SFP validation failed       10G(D) --
Eth2/9        1      eth  access down    SFP validation failed       10G(D) --
Eth2/10       1      eth  access down    SFP validation failed       10G(D) --
Eth2/11       1      eth  access down    SFP validation failed       10G(D) --
Eth2/12       1      eth  access down    SFP validation failed       10G(D) --
Eth2/13       1      eth  access down    SFP validation failed       10G(D) --
Eth2/14       1      eth  access down    SFP validation failed       10G(D) --
Eth2/15       1      eth  access down    SFP not inserted            10G(D) --
Eth2/16       1      eth  access down    SFP not inserted            10G(D) --
show interface transreceiver output sample
Ethernet2/1
    transceiver is present
    type is 10Gbase-LR
    name is CISCO-FINISAR
    part number is GLC-T
    revision is 1.0
    serial number is MTC13360123
    nominal bitrate is 3200 MBit/sec
    Link length supported for 9/125um fiber is 32 km
    Link length supported for 9/125 um fiber is 3200 m
    Link length supported for 50/125um fiber is 320 m
    Link length supported for 62.5/125um fiber is 320 m
    Link length supported for copper is 32 m
    cisco id is --
    cisco extended id number is 4
Ethernet2/2
    type is 10Gbase-LR
    revision is 1.0
    serial number is MTC13360106
    cisco id is --
Ethernet2/3
    type is 10Gbase-LR
    revision is 1.0
    serial number is MTC13360133
    cisco id is --
8 Replies 8
allan.thomas
Level 8
Level 8
Please refer to the following link regarding configuring networking interfaces, the issue here is that the interfaces are configured for 10Gb and do not auto sense if you change the SPF, you need to manually configure the speed to 1000:
http://www.cisco.com/en/US/docs/switches/datacenter/nexus5000/sw/configuration/guide/cli/BasicEthernet.html#wp1266647
Allan
Please rate helpful posts, thank you.
I tried same things as per document stil not able to fix the issue.
Please help
I configured speed 1000 and then inserted the module , still the error is SFP validation failed
couple of things to check
What version of software are you running?
I know you need at least Cisco NX-OS 5.0(3)N1(1) to support GLC-T
If the softare is up to date, than it is comparability issue, try a different GLC-T from a different vendor:
You are running a supported release, as support was introduced in 5.0.3(N1)1 as mentioned in the previous post which you mentioned in your original post. the issue shouldn't be attributed to the version of Nxos but rather the Gbics you are using so specifying the speed should have worked for you. Incidentally did you do a 'shut' and a 'no shut' once the Gbic was connected after specifying the speed, as in some cases the interface could be error disabled.
Can you post the output of a 'show int eth?/? Transceiver calibrations' like I the example below:
N5K# sh int eth1/21 transceiver calibrations
Ethernet1/21
type is SFP-1000BASE-T
name is CISCO-METHODE
part number is SP7041_Rev_F
revision is F
serial number is 00000MTC162802H3
nominal bitrate is 1300 MBit/sec
Link length supported for copper is 100 m
cisco id is --
hi
I have done shut & no shut before and after inserting the module also but the result is same
As you requested the infor please find below
Ethernet2/1
    type is 10Gbase-LR
    revision is 1.0
    serial number is MTC13360008
    cisco id is --
Transceiver calibration is invalid
Ethernet2/2
    type is 10Gbase-LR
    revision is 1.0
    serial number is MTC13360128
    cisco id is --
Ethernet2/3
    type is 10Gbase-LR
    revision is 1.0
    serial number is MTC13360139
    cisco id is --
--More--
The question at this point is whether the SFPs are from a supported manufacturer? There is an unsupported command that you can use 'service unsupported transceiver', if you enable this command this will only help you to determine the validity of the SFP as it will bypass the validation checks. At no point should you continue to use this command in production as it is not supported by TAC, please also see the following link referring to the use of this command by Cisco employees. If the SFPs still do not pass the validity I strongly urge you to escalate the matter to Cisco TAC for further and assistance:
https://supportforums.cisco.com/thread/2014677
Allan
What Allan said. NB. make sure the interface isn't a member of a port-channel otherwise the interface speed command will not be available.
Soleymani
