Going from an older UNIVERSAL image to LAN BASE - IE2000
Havenra89
I am not using any routing, however I do need SVI's for management purposes. If i upgrade to a newer version of IOS for an IE-2000, I will still be able to use SVI's and assign an IP right?
Here is the LANBASE specs:
LAN Base license
Additional features
Layer 2 switching
VTPv3, EtherChannel, Voice VLAN, Flexlink
Security
IPv4 Port-Security, DHCP Snooping, Dynamic ARP Inspection, IP Source Guard, 802.1x, Guest VLAN. MAC Authentication Bypass, 802.1x Multi-Domain Authentication, Storm Control, Trust Boundary, Access-List (ACL)
Quality of service
IPv4 Ingress Policing, Rate-Limit, Egress Queuing/Shaping, AutoQoS, PROFINET QoS
Management
Port-Based DHCP, Storm Control - Unicast, Multicast, Broadcast, SPAN Sessions, RSPAN, DHCP Server, Customized TCAM/SDM Size Configuration, Embedded Event Manager (EEM)
Industrial Ethernet
IEEE 1588 PTPv2
IPv4 routing
IPv4 static routing
IPv6 routing
IPv6 host support, HTTP over IPv6, SNMP over IPv6
Reza Sharifi
Using an SVI for management purposes should not be an issue. According to the specs above, LAN BASE also supports "IPv4 static routing".
So, most likely it supports multiple SVIs.
