Graymail Engine, SBRS Engine, AV Engine Get Restarted in IronPort
rockbd
Hi All
Recently my IronPort's(Email Security) Graymail Engine, SBRS Engine, AV Engine get automatically restarted with the following message:
Graymail Engine: Process restarted due to watchdog health check failures.
Sophos Engine: Process restarted due to watchdog health check failures.
SBRS Engine: Process restarted due to watchdog health check failures.
As far as my understanding it is done due to watchdog health check. Why this is happening? Should i worry or it is just normal process of Ironport.
check if the bug below applies. What is the CPU usage when this occurs ?
Bug Search Tool
Bug SearchCSCvf77729
Help | Feedback Feedback
Watchdog processes are too expensive, and timeout improperly
CSCvf77729
Description
Symptom:
When the ESA is under heavy CPU load, older model appliances can improperly register watchdog timeouts.
Wed Aug 30 06:13:30 2017 Critical: repeng: Watchdog timed out:
30 Aug 2017 06:14:30 +1000 SBRS Engine: Process restarted due to watchdog health check failures.
Conditions:
This condition can occur when the CPU load is around double the number of cores on the appliance.
Workaround:
None, the watchdogs and process restarts should not cause problems, but it indicates that your overall CPU load is excessive.
My IronPort appliance is Cisco C600V and the OS version is 11.1.0-128. Am i running the leatest Iropnport Email Appliance or Cisco introduce new one already.
I didn't find any warning regarding CPU utilization. The CPU threshold is set to 85 %. So is this for the CPU or other factor.
Any other suggestion.
