gre tunnel with dynamic IP
Haris P
Level 4
Level 4
Dear ,
I'm trying to create GRE tunnel between two Cisco 877 routers by using ddns
interface Tunnel1
ip address 10.10.10.1 255.255.255.252
tunnel source Dialer1
tunnel destination hat45.dnsalias.net
The domain name under hat45.dnsalias.net is resolving immediately to IP and when I do show run tunnel destination is showing me as IP address and this is making problem . Because remote end point for the tunnel is dynamic IP and it's changing everytime . I want to use tunnel destination as domain name and not as IP ? Is there is any way
5 Replies 5
michael.leblanc
Level 4
Level 4
I would assume that the IP address is changing frequently because you are not keeping the tunnel up.
Perhaps you could keep the tunnel up using GRE Keepalives.
e.g.:
interface Tunnel0
keepalive 5 4
The only time you would likely see a change in IP, would be following a power outage.
Not the perfect solution you are seeking, but it could significantly improve your situation.
hennigan
Try:
interface tunnel1
ip ddns update hat45.dnsalias.net
Also search Cisco docs for "ip ddns" show and debug commands, options.
The issue is that when i type
" tunnel destination hat45.dnsalias.net " its translating to IP .
As i know with IPsec it's working ,but i want to user GRE
http://www.cisco.com/en/US/tech/tk583/tk372/technologies_configuration_example09186a00801dddbb.shtml
Haris
Did you ever find a solution on that? i want to do exactly the same thing..
Was looking for something similar - ended up with an EEM script.
conf t
event manager session cli username "somelocalusername"
event manager applet Update-GRE-Tunnel
 event timer watchdog time 1800
 action 1.0 cli command "enable"
 action 2.0 cli command "config t"
 action 3.0 cli command "interface Tunnel1"
 action 4.0 cli command "tunnel destination hat45.dnsalias.net"
 action 6.0 cli command "end"
 action 7.0 cli command "wr"
end
