GSR 12008 error
contador7
I have a GSR 12008 and I'm getting the below error message below and I've been unable to find a symptom/solution. Has anyone encountered this and is there a fix for this? Thanks.
Tim
00:03:19: %ENV_MON-4-ONEPEM: Only one PEM is available in GSR
vijayasankar
Level 4
Level 4
HI,
Couldn't get a hit on error message decoder for this message..
Can you check whether you have any issues in the power entry modules on this GSR.
-VJ
rharvey57
Contador,
Do you have 1 or 2 power supplies installed? Did you lose one? You can perform a show env or sho hardware to investigate,'
Keep me posted,
rjh
I have one power supply installed (tried it in both slots, but got the same error) below ist he show env & sh hardware..
Router#show environment
Slot # Hot Sensor Inlet Sensor
(deg C) (deg C)
0 28.5 23.5
3 25.0 20.5
7 26.5 24.0
16 26.0 24.0
17 25.0 23.0
18 22.0 24.5
19 22.0 22.0
20 22.5 21.5
24 NA 27.0
Slot MBUS | CARD | PLIM Voltage Lines
# 5V | 3.3V 5.0V 2.5V | V3 V4 V5 V6 V7 V8
0 5056 3284 5008 - - - - - - -
3 5128 3288 4976 - - - - - - -
7 5120 3296 4992 2496 - - - - - -
16 5096 - - - - - - - - -
17 5104 - - - - - - - - -
18 5104 3288 - - - - - - - -
19 5096 3284 - - - - - - - -
20 5104 3308 - - - - - - - -
24 5104 - 5552 - - - - - - -
Slot # 5V MBUS 5V 48V AMP_48
(mv) (mv) (Volt) (Amp)
24 5552 5104 48 7
Slot # Fan Information
16 Voltage 25V Speed fast: Main Fans Ok Power Supply fans Ok
17 Voltage 25V Speed fast: Main Fans Ok Power Supply fans Ok
Slot # Card Specifc Leds
16 MBUS-OK
17 MBUS-OK
18 MBUS-OK
19 MBUS-OK
20 MBUS-OK
Router#show hardware
IOS (tm) GS Software (GSR-P-M), Version 12.0(31)S, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2005 by cisco Systems, Inc.
Compiled Sun 17-Apr-05 01:32 by kellythw
Image text-base: 0x50010F40, data-base: 0x54382000
ROM: System Bootstrap, Version 11.2(20030108:132517) [jkuzma-112 2.2] RELEASE SOFTWARE
BOOTLDR: GS Software (GSR-P-M), Version 12.0(31)S, RELEASE SOFTWARE (fc1)
Router uptime is 3 minutes
Uptime for this control processor is 3 minutes
System returned to ROM by reload at 16:28:47 UTC Mon Jan 8 2007
System image file is "slot0:gsr-p-mz.120-31.S.bin"
cisco 12008/GRP (R5000) processor (revision 0x01) with 262144K bytes of memory.
R5000 CPU at 200Mhz, Implementation 35, Rev 2.1, 512KB L2 Cache
Last reset from power-on
1 Route Processor Card
2 Clock Scheduler Cards
3 Switch Fabric Cards
1 four-port OC3 POS controller (4 POS).
1 six-port DS3 controller (6 DS3).
1 Ethernet/IEEE 802.3 interface(s)
4 Packet over SONET network interface(s)
507K bytes of non-volatile configuration memory.
32768K bytes of Flash PCMCIA card at slot 0 (Sector size 128K).
8192K bytes of Flash internal SIMM (Sector size 256K).
Router#
The message that you see is not due to a error.
As you have only one PEM installed in the GSR, For informational purpose, It just reports that there is only one power supply installed in GSR.
Hoep this helps.
-VJ
