02-07-2018 06:10 AM - edited 03-08-2019 01:45 PM
I have a SG550XG-8f8t switch. I would like to activate the GVRP but it does not appear in the web interface.
This option should appear in VLAN Management > GVRP Settings.
Any idea? Is necessary activate it by command line?
Thank you.
Best regards.
Solved! Go to Solution.
02-07-2018 07:09 AM
Can you please change the Display Mode from "Basic" to "Advanced" and see if there is any improvement.
Best regards,
Antonin
02-07-2018 07:09 AM
Best regards,
Antonin
02-07-2018 07:13 AM
Thank you so much.
It was that ;)
