Hard Setting Speed on 10gb Ports
JCMG-Network
Is it possible to manually change the speed of a tengigabitethernet port on a 4506 switch? When I go into the interface I am not presented with the "speed" command like I would be on a normal interface.
What I would like to do is hard set them to 1gb since the fiber connection too long to properly run at 10gb and is causing some performance issues.
6 Replies 6
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
Fiber ports don't usually have multiple speeds.  However, if your 10g port is SFP+, you should be able to use gig SFPs.
I believe they are SFP+ I will need to double check. I know I can just put in gig SFPs but I was trying to find a way around without having to buy anything.
Can you share below output
sh int tengig x/x
sh int tengig x/x transceiver details
sh run int tex/x
sh inventory
Naveen
****Rate if its helpful***
Here you go, I was able to get everything except the "sh int tengig x/x transceiver details" it was not an option. I could do a "show int transceiver details" but it did not produce any output. The SFP that is in there should be a X2-10GB-SR.
3B-4506#sh int tengig 1/1
TenGigabitEthernet1/1 is up, line protocol is up (connected)
  Hardware is Ten Gigabit Ethernet Port, address is 0024.9719.4ec0 (bia 0024.9719.4ec0)
  MTU 1500 bytes, BW 10000000 Kbit, DLY 10 usec,
  Keepalive set (10 sec)
  Full-duplex, 10Gb/s, link type is auto, media type is 10GBase-SR
  input flow-control is on, output flow-control is off
  Last input 00:00:00, output never, output hang never
  Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 0
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute input rate 7803000 bits/sec, 1328 packets/sec
  5 minute output rate 1593000 bits/sec, 962 packets/sec
     116208938 packets input, 74380462222 bytes, 0 no buffer
     Received 20029787 broadcasts (12661121 multicasts)
     73166419 packets output, 18616178465 bytes, 0 underruns
     0 lost carrier, 0 no carrier
3B-4506#
3B-4506#sh run int tengig 1/1
Building configuration...
Current configuration : 134 bytes
interface TenGigabitEthernet1/1
 switchport trunk native vlan 150
 switchport mode trunk
end
3B-4506#sh inventory
NAME: "Switch System", DESCR: "Cisco Systems, Inc. WS-C4506-E 6 slot switch "
PID: WS-C4506-E        , VID:    , SN: FOX1251GNWF
NAME: "Linecard(slot 1)", DESCR: "Supervisor II+10GE with 2 10GE X2 ports, and 4 1000BaseX SFP ports"
PID: WS-X4013+10GE     , VID: V06, SN: JAE130201KY
NAME: "TenGigabitEthernet1/1", DESCR: "10Gbase-SR"
PID: TRT2005EN-C15TAA  , VID: 04 , SN: ONJ1521003Z
NAME: "GigabitEthernet1/3", DESCR: "1000BaseSX"
PID: FTLF8519P2BCL-CS  , VID: B  , SN: FNS13041JXP
NAME: "GigabitEthernet1/4", DESCR: "1000BaseSX"
PID: FTLF8519P2BCL-CS  , VID: B  , SN: FNS13041KR0
NAME: "Linecard(slot 2)", DESCR: "10/100/1000BaseT (RJ45)V with 48 10/100/1000 baseT voice power ports (Cisco/IEE"
PID: WS-X4548-GB-RJ45V , VID: V11, SN: JAE1247156F
NAME: "Linecard(slot 3)", DESCR: "10/100/1000BaseT (RJ45)V with 48 10/100/1000 baseT voice power ports (Cisco/IEE"
PID: WS-X4548-GB-RJ45V , VID: V11, SN: JAE1305215E
NAME: "Linecard(slot 4)", DESCR: "10/100/1000BaseT (RJ45)V with 48 10/100/1000 baseT voice power ports (Cisco/IEE"
PID: WS-X4548-GB-RJ45V , VID: V11, SN: JAE13041VXJ
NAME: "Fan", DESCR: "FanTray"
PID: WS-X4596-E        , VID:    , SN: FOX1251GPNE
NAME: "Power Supply 1", DESCR: "Power Supply ( AC 4200W )"
PID: PWR-C45-4200ACV   , VID: V03, SN: AZS12460A2J
NAME: "Power Supply 2", DESCR: "Power Supply ( AC 4200W )"
PID: PWR-C45-4200ACV   , VID: V03, SN: AZS12460ANE
3B-4506#
3B-4506#
Pls check this link.
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst4500/12-2/01xo/configuration/guide/config/sw_int.html#wp1077316
Naveen
****Rate if it is helpful***
cyberhunt
You can try the following command and see if this helps.
configure terminal
hw-module uplink select (Tengigabitethernet | Gigabitethernet | All)
Hope it helps.
