Hardware Assisted NAT
rrajmohan
What is hardware assisted NAT? What are its disadvantages, will it result in high CPU utilization
Philip D'Ath
Its when you have silicon with NAT functionality.  It should result in the CPU having less work to do.
Reza Sharifi
It means that NAT can't be handled entirely by the hardware and needs assistant from the software (CPU). If you are doing a few NAT statements, it may not be significant, but if you are deploying a lot of NAT statements you want to watch the CPU.
Thank you Reza, for your clarification. Following are few of my addition queries.
Hardware NAT:
Assuming that NAT is handled fully in hardware, how does the NAT translation occurs.
Are the NAT rules get pre-programmed in some sort of hardware.
Will there be some interrupt / sub-routines to handle NAT translations.
How CPU is totally taken off from NAT jobs.
Hardware-Assited NAT:
Which part of NAT function is handled by hardware.
What are NAT translation condition which requires assistance from CPU
