Hardware error (sh platform hardware ip route ipv4..)
Hi guys,
We had an issue with our Cat4506 with Sup8-e. Whenever we did a firewall failover, connectivity was lost to a certain part of the network. After some digging around with a consultant, we found the error ->
sh platform hardware ip route ipv4 network 192.168.1.0 255.255.255.0
09:27:38 § 000764: v4 192.168.1.0/24 --> vrf: SCADA (9)
09:27:39 § adjStats: true fwdSel: 2 Dug: 0 mrpf: 0 (None) fwdIdx: 0 ts: 0
09:27:39 § adjIndex: 47860 vlan: 64 port: Po64 (1160)
09:27:39 § fwdCtrl: 5 cpucode: 3 sifact4: FwdToCpu sifact6: FwdToCpu
09:27:39 § sa: 00:08:E3:FF:FC:04 da: A2:A4:0E:00:00:0A
09:27:39 §
09:27:39 § 000773: v4 192.168.1.0/24 --> vrf: DSO (5)
09:27:39 § adjIndex: 47904 vlan: 65 port: Po20 (1116)
09:27:39 § sa: 00:08:E3:FF:FC:04 da: A2:A4:0E:00:00:0E
09:27:31 § 000772: v4 192.168.1.0/24 --> vrf: DSO (5)
09:27:31 § adjStats: true fwdSel: 2 Dug: 0 mrpf: 0 (None) fwdIdx: 0 ts: 0
09:27:31 § adjIndex: 47804 vlan: 65 port: Po63 (903)
09:27:31 § fwdCtrl: 5 cpucode: 3 sifact4: FwdToCpu sifact6: FwdToCpu
09:27:31 § sa: 00:08:E3:FF:FC:04 da: A2:A4:0E:00:00:0E
09:27:31 §
09:27:31 § 000773: v4 192.168.1.0/24 --> vrf: SCADA (9)
09:27:31 § adjIndex: 47858 vlan: 64 port: Po10 (850)
09:27:31 § sa: 00:08:E3:FF:FC:04 da: A2:A4:0E:00:00:0A
Routing back from vrf: SCADA, was forwarded out the wrong port, Po10. I should have been forwarded out Po20 like the DSO vrf.
Can someone elaborate on the output, which part of the switch are we looking into and have could this issues have been detected? Could cef-table consistency tjek have helped?
Best regards,
Michael
sheahm
Let me know if this is still an issue. We can discuss this further. We encountered exactly same scenario month back. Spent 1 month T shooting checkpoint fail-over that turn out to be problem with Cisco 4500x
We resolved the issue - it was due to a firmware bug, that were caused when SVI's was terminate in a VRF.
What I'm seeking is an explanation for the CMDlets, and more details about this level of troubleshooting.
