Interface member of non-existence Port Channel
indiankhiladi
two switches are connected through an interface
on both the interfaces "channel-group" command is not present (they are not part of any port channel)
neither any port channel is created on any of the switches ("sh run int port-channel xyz" doesn't show anything)
however, there is one port channel on both sides which shows respective interfaces to be a part of it
trying to figure out why
Switch A Model & IOS -> WS-C3850-12XS (cat3k_caa-universalk9 03.07.04E)
Switch B Model & IOS -> WS-C3850-24XS (cat3k_caa-universalk9 03.07.04E)
7 Replies 7
Hello
@indiankhiladi wrote:
There is no configuration related to any port-channel (say Po1 on both sides) in the running config ("sh run int po1" doesn't show anything) (on both switches)
Interesting is that still one port-channel (say Po1 on both sides) shows Gi0/0/0 to be its member. (sh int po1) (on both switches)
Not sure i understand , You say you have a port-channel applied but it no physical interfaces shows any port-channel configuration, The you say you dont see any port-channel in the running config but then you say you do?
Are you aware you can create logical PC's without specifying any physical interfaces? - Have you tried reloading the switch it could be a ghost entry from a previous change?
Kind Regards
Paul
Hello
Did you try reloading the switches?, If these are in production then obviously dont do the reload unless somehow this is negating your connectivity, which i doubt it will be?
Kind Regards
Paul
yes they are in production
and i don't want to reload
i need to know why this is happening (i mean get to a valid justification)
Hello
It could be a ghost configuration that after a reload would clear, However saying that can you post what you are seeing to clarify
Kind Regards
Paul
could it be automatically created by PaGP or LACP ?
try related show commands
