Harmonic
hclapper
Community Member
I am looking for a document that states the WS-C3750G-24TS-E1U is compliant with the harmonic spec. EN 61000-3-2.
j-marenda
Level 4
Level 4
The datasheet of 3750-E found at
http://www.cisco.com/en/US/partner/prod/collateral/switches/ps5718/ps7077/product_data_sheet0900aecd805bbe67.html
(also available as pdf)
states that the power-supplies are complient.
Hope this help's,
Jürgen Marenda.
Hello Jürgen,
The answer is correct for the 3750-E series. I am looking for WS-C3750G-24TS-E1U.
Sorry,
you are right,
the datasheet for the 3750G states only
EN 55022: 1998 (CISPR22)
EN 55024: 1998 (CISPR24)
and not the EN61000-...,
they look at other EMV aspects.
Since EN 61000... is from 2001,
the 3750G datasheet should mention to meet it,
since the switch is from 2003 i think.
Kuljeet Singh Kohli
Community Member
Harold,
The WS-C3750G-24TS-E1U does NOT comply to the spec EN 61000-3-2. Please see Table 5. (Safety and Compliance)
the following Cisco Catalyst 3750 Series data sheet document.
http://www.cisco.com/en/US/partner/prod/collateral/switches/ps5718/ps5023/product_data_sheet0900aecd80371991.html
Hope this helps.
-  Kuljeet Singh Kohli
